Clicking Noise in Neutral Without Clutch Pressed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Clicking Noise in Neutral Without Clutch Pressed
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 10-23-2011, 02:41 PM   #1
ErikPeterson
There is a click/scrape noise coming from the transmission area of the jeep when it idles in neutral. As soon as I push in the clutch pedal it stops. Upon letting the clutch pedal back the click...click...clicking continues. Most of the threads I've read say it is the throwout bearing. But I can't find on any sites a throwout bearing for a 1990 2.5L. Am I missing something?
ErikPeterson is offline   Reply With Quote Quick reply to this message
Unread 10-23-2011, 03:07 PM   #2
youngjeepr
How quickly does your clutch ingage? Does it ingage all of the sudden? How far off the floor is it when it engages?
[COLOR="Red"][/COLOR][SIZE="5"][/SIZE]88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
[URL="http://www.jeepforum.com/forum/f319/"][SIZE="4"][COLOR="Red"][CENTER][B]Utah Jeep Crew[/B][/CENTER][/COLOR][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f22/youngjeeprs-build-take-2-a-2012985/"][COLOR="Red"][U][B][CENTER][SIZE="4"]Build Thread[/SIZE][/CENTER][/B][/U][/COLOR][/URL]
youngjeepr is offline   Reply With Quote Quick reply to this message
Unread 10-23-2011, 08:17 PM   #3
ErikPeterson
I would say fairly quick. 2 or 3 in. And it never seems to be pressed enough for 2nd. Always a little extra force needed.
1990 Wrangler YJ "Linda"-Project
2012 Patriot Sport FD1 "Beth"-DD
Unread 10-23-2011, 08:43 PM   #4
youngjeepr
Sounds like your throw out bearing to me.... Once you get it in gear and start to let the clutch out does it engage quickly?
Unread 10-23-2011, 08:56 PM   #5
ErikPeterson
Yes I'd say so. I figured it was the throwout bearing, but I can't find a site with one for an ax-5 older than 94. Is there a different part?
Unread 10-23-2011, 09:02 PM   #6
youngjeepr
Try napa I usually just go into the local part store I don't get very many parts online
Unread 10-24-2011, 05:07 AM   #7
ErikPeterson
How much do you think its gonna run me?
Unread 10-24-2011, 12:43 PM   #8
jmmorgan82
A t/o bearing for my Mustang was like $30.
jmmorgan82 is offline   Reply With Quote Quick reply to this message
Unread 10-24-2011, 04:56 PM   #9
youngjeepr
http://napaautoparts.com/Catalog/Cat...(P_RecType%3aA)
that one is $229.00 online price
Unread 10-24-2011, 05:06 PM   #10
jmmorgan82
The bearing and slave cylinder assembly is $148 at O'reilly and the Bearing alone is $24 for a Sachs bearing.
Unread 10-24-2011, 08:35 PM   #11
ErikPeterson
Didn't click today. Any ideas?
