Clicking noise from front driver side wheel area. PLEASE HELP - JeepForum.com
post #1 of 7 Old 09-02-2011, 07:46 PM Thread Starter
Checkalicious
I just changed my wheels to 31's and now when I'm going 20-25mph and apply brakes I get a weird clicking noise from the front driver side. If I lightly apply the brakes no clicking noise, but when I hit the brakes like a normal stop i.e. pulling up to a stop sign it makes the clicking noise. Also if I really apply the brakes a little more harder its a real rapid clicking noise. Now when the clicking noise is going on I have no vibration in the steering wheel.
Now the tires I typically run my jeep on is the factory size (do this for mpg's). I recently rebuilt my power steering gear box. But the gear box has been silent and working proper for about a month now. I'm guessing I won't be going wheeling tomorrow now, but still trying to for sunday.
Any help would be awesome thanks for your time. Also I checked the u-joint already and seems to be in good working order on both sides
Checkalicious is offline
post #2 of 7 Old 09-02-2011, 09:15 PM
timatoe
timatoe's Avatar
How did you check the u-joints? Just curious. It's the first thing I thought of. If it's actually brake related you would typically be able to feel it.
timatoe is offline
post #3 of 7 Old 09-02-2011, 10:18 PM Thread Starter
Checkalicious
I jacked the Jeep up and grabbed the u-joint and was trying to move it around to feel for play. There wasn't any on the driver side or passenger side. I was thinking u-joint as well. Did I check it right cause I was just reading other threads about u-joint issues and that seemed to be the common answer for checking them.
post #4 of 7 Old 09-02-2011, 10:19 PM Thread Starter
Checkalicious
Also I was thinking the same thing with brakes typically a noise like that would give a vibration in the steering wheel. Could it be a bearing, or some other junk like that?
post #5 of 7 Old 09-03-2011, 04:58 AM
tloftin86
did you grease the u joints and everything else up under there? When mine did that it was in the rear and it turned out my yoke was warped
tloftin86 is offline
post #6 of 7 Old 09-03-2011, 06:15 AM
ssyj94
Its likely you have worn caliper brackets. Take the caliper off and look for divets in the slides. My DD xj did the samething when moving slow gently ride the brakes and it goes away.
My build:
ssyj94 is offline
post #7 of 7 Old 09-03-2011, 07:02 AM Thread Starter
Checkalicious
No I didn't grease stuff up yesterday (no clue why I didn't) but I will now. Also I will check the caliper brackets. Thanks everyone hoping these ideas work for two reasons they sound cheap and I'll be able to hit the trails up today.
clicking noise driver front wheel area HELP!! halo1 TJ Wrangler Technical Forum 1 06-13-2011 08:36 PM
Squeaking noise from driver side wheel jeepuga TJ Wrangler Technical Forum 2 03-08-2011 08:05 AM
Whump Whump Noise Coming from Driver Side Front Wheel 99fourbanger TJ Wrangler Technical Forum 10 02-01-2011 01:25 PM
Scraping noise from driver side rear wheel LOCAL TJ Wrangler Technical Forum 2 06-27-2009 09:36 PM
Heating up in the front driver side brake area. SpoiledRotten TJ Wrangler Technical Forum 2 09-19-2007 06:45 PM
