Clicking noise comming from the front end?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Clicking noise comming from the front end??
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-21-2010, 09:16 PM   #1
divewall14
2003 WJ
I have a 1995 Jeep JY with the D30 disconnect. The 4X4 disconnect works great but there is a clicking noise when the car is moving. the faster I go the more clicks, but as i break the noise becomes much louder. I was wondering if this was a bearing problem or a U joint problem. I was thinking of re building the entire axle this summer but the noise has become progressively worse.
thanks for the help, the picks are from the summer but nothing has changed except the diff cover being re painted and cleaned.
divewall14 is offline   Reply With Quote Quick reply to this message
Unread 01-21-2010, 10:06 PM   #2
mrmud4x4
I had same problem.....1st one after purchase.....front wheel bearings.
You can look at the front Ujoints easily and see if they are worn around the ujoint cap.
If you put the jeep in 4wd and turn in circles while driving, a bad ujoint up front will make a noticable popping noise while turning. Gravel/sandy parking lots work great for this.
Set your front axle on jack stands, push top and bottom of wheel/tire in and out (wobble)......any play? .....wheel bearing.
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline   Reply With Quote Quick reply to this message
