click pop click pop???? - JeepForum.com
post #1 of 23 Old 09-07-2010, 05:32 AM Thread Starter
Brown6041
put in a d30 that had tj shafts and an aussie locker in it when i acclerate it pulls hard left and when i turn right it makes a click pop noise like binding or something never driven with a locker so not sure it this is common but it doesnt seem right.
Brown6041 is offline
post #2 of 23 Old 09-07-2010, 05:48 AM
GrouchyTim
It's not.
'88 YJ with SOA and SYE and a bunch of custom crap from BWF in Chesapeake.
'97 XJ on 8" lift, double triangulated rear, long arm 3 link front, Eaton/60 with 5.14 gears.
GrouchyTim is offline
post #3 of 23 Old 09-07-2010, 06:45 AM Thread Starter
Brown6041
does anyone know what it could be or why its happeneing
post #4 of 23 Old 09-07-2010, 06:50 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Its either a u joint of the locker. You gotta pull the cover to check it.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 23 Old 09-07-2010, 06:55 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Tolerances on the Aussie could be off. I agree on checking the u-joints.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #6 of 23 Old 09-07-2010, 07:55 AM
Djsthe1
When I installed my TJ shafts I also had to swap out the rotors, the YJ rotors were rubbing the ears of the axle. The TJ rotors give me the right clearance, theres only like a 1/8 difference between the two. Its something to do with the difference in bearing..
Djsthe1 is offline
post #7 of 23 Old 09-07-2010, 08:37 AM Thread Starter
Brown6041
ok i looked inside it and the locker looks to be ok no chips or anything like that. Which u-joint are yall talking about the axle u-joints? Also just for the record i took the front drive shaft off and everything is fine so i assume it is in the axle somewhere because from my understanding the locker doesnt really do anything unless the drive shaft is applying tourqe to it .........
post #8 of 23 Old 09-07-2010, 12:10 PM
pasinbuy
This may be a stupid question but, is it pulling only on hard surfaces or is it pulling on dirt also?
pasinbuy is offline
post #9 of 23 Old 09-07-2010, 12:14 PM Thread Starter
Brown6041
um not a stupid question im not sure ,i just know after i putthe axle in i went to take a test drive and it was pulling hard left when i hit the gas and when i took slow right turns it made loud CLICK POP CLICK POP almost like if you had a bas cv joint in a car...........but when i take the driveshaft off and drive around i doesnt do that i have new u-joints in the driveshaft too just to clarify. i hear it shoul dmake a ratchet noise which it does when i jacked up the front end and checked it
post #10 of 23 Old 09-07-2010, 01:03 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
did you check the tolerances to the Aussie recommended specs?
Poke is offline
post #11 of 23 Old 09-07-2010, 04:28 PM Thread Starter
Brown6041
what are they and how do i check them??
post #12 of 23 Old 09-07-2010, 05:40 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Call aussie I don't have them anymore. Both aussie and lockrights come with gap tollerance spec in the install directions
Poke is offline
post #13 of 23 Old 09-07-2010, 06:36 PM
I8AHUMR
It doesn't do it with the driveshaft in but it does with it installed in two-wheel drive??? Even in two-wheel there is no torque applied. Only torque when in four-wheel. Did I miss something?
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #14 of 23 Old 09-07-2010, 06:46 PM Thread Starter
Brown6041
thats a good point i think ur right so if that is the case does this mean the transfer case is not fully disengaged. not sure how this would happen.
If there was slack in your linkage shifting from 4h to 2wd could it cause it to maybe catch or somethin??????
everyone ask ur friends i am and i really wanna drive my jeep
post #15 of 23 Old 09-07-2010, 06:51 PM
I8AHUMR
I think people have encountered this issue when towing with a lunchbox up front with the driveshaft installed. I believe there's something with the 231 (yj years) that results in the front and rear not being 100% decoupled and this issue was experienced when a lunchbox was installed during flat towing. I can't remember exactly what I've read but this issue has been seen before. The fix was to replace a certain piece in the xfer case which results in the front and rear being fully disengaged. I can't for the life of me remember exactly what it was. Can someone chime in that knows what they're talking about?
I8AHUMR is offline
Engine Click Click Click when trying to start nonnaca TJ Wrangler Technical Forum 3 07-24-2009 12:35 PM
Jeep won't start click, click,found loose wire scojean YJ Wrangler Technical Forum 8 07-06-2009 07:02 PM
'95 2.5 liter has no spark right away... then CLICK CLICK CLICK and it works? Stealth0ps YJ Wrangler Technical Forum 2 06-15-2009 09:42 PM
I have developed a 'click...click...click' giggityjeeper YJ Wrangler Technical Forum 11 03-03-2008 06:14 PM
click click ... clutch problems? jmasin TJ Wrangler Technical Forum 2 07-01-2003 08:14 AM
