click??? - JeepForum.com
post #1 of 4 Old 05-13-2002, 02:03 PM Thread Starter
sk8pr0
click???
I got a new rear yoke a few weeks ago and now there is a small issue. When I engage the clutch (let the pedal out) there is a click. Most of the time it is just once then it stops, but sometimes it is a couple clicks in a row. anyone have any ideas?
Red 93 YJ
30/9.5" tires
Lift and Lock soon (just need the $)
sk8pr0 is offline
post #2 of 4 Old 05-14-2002, 02:40 AM
JeepinNH
I have heard clunks and clanks, the typical worn ujoint noise but not a click. Can you tell what general area the noise is coming from?
91 Wranger, 3" body lift, 33" tires
everything else - stock
thinking about RC lift
Wife's has 91 Wrangler, Shackle Lift running BFG 31" "Yellow"
JeepinNH is offline
post #3 of 4 Old 05-14-2002, 10:11 AM Thread Starter
sk8pr0
i know it isn't ujoints cause i just replaced them. i know it is coming from underneath but i don't trust anyone enough to climb under there while they engage the clutch, lol
Red 93 YJ
30/9.5" tires
sk8pr0 is offline
post #4 of 4 Old 05-14-2002, 12:24 PM
ezgoing
ezgoing's Avatar
Is it possible that there is a little play in the rear pinion yoke and/or rear diff? If not there may be play in the area that the driveshaft mates to the transfer case. Just two ideas that may help track it down.
'92 YJ Sahara
1 1/4" shackle lift for now soon to be some sort of lift
31" Bridgestone Dueller A/Ts on AR-767 wheels
'67 Ford Galaxie 500 (passes everything but the gas station)
"What do you mean I can't make it, watch me!" = oops
ezgoing is offline
Engine Click Click Click when trying to start nonnaca TJ Wrangler Technical Forum 3 07-24-2009 12:35 PM
Jeep won't start click, click,found loose wire scojean YJ Wrangler Technical Forum 8 07-06-2009 07:02 PM
'95 2.5 liter has no spark right away... then CLICK CLICK CLICK and it works? Stealth0ps YJ Wrangler Technical Forum 2 06-15-2009 09:42 PM
I have developed a 'click...click...click' giggityjeeper YJ Wrangler Technical Forum 11 03-03-2008 06:14 PM
click click ... clutch problems? jmasin TJ Wrangler Technical Forum 2 07-01-2003 08:14 AM
