Cleaning up the wiring under the hood - JeepForum.com
post #1 of 7 Old 07-14-2013, 11:36 PM Thread Starter
Dwarf
1987 YJ Wrangler
I have an 87 yj that the po swapped in a 76 258. There is a rats nest of wiring that went to things no longer present. I'd like to get rid of the junk, but , since its missing stuff, I can't know what all these connectors originally went to. What is the best way to figure out what I can trim back?
Dwarf is offline
post #2 of 7 Old 07-15-2013, 02:51 AM
Dingo1033
Somebody needs to send you pics of a stock 87 engine bay. Bump
"I may not change the world, but I'll damn sure leave a scar"
Dingo1033 is offline
post #3 of 7 Old 07-15-2013, 04:20 AM
jsawduste
2006 YJ Wrangler
Ahh, wiring diagram maybe ?
jsawduste is offline
post #4 of 7 Old 07-15-2013, 04:32 AM
Dingo1033
That may work better than a pic. Actually yeah that's a better route
post #5 of 7 Old 07-15-2013, 07:12 AM
superj
i would say you could look at mine but its a long drive to your town from corpus. my 87 has lots of wiring removed because i didn't need it
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 7 Old 07-15-2013, 07:49 AM
jimbos76cj
Its a cut and paste from another site but heres the wiring in my 89 yj.
Got a call back from the powder coater about the dash today.. to blast it, lay down a high zince rust inhibiting primer and gloss black textured finish... $100. Sold! Inbetween down pours today I snuck into the shop and worked on the wiring a little more. Heres what Ive got done
I was able to run the new wires through the stock harness hoops. I measured and cut all the end to the right length and got em hooked up.
Then I Ran some loom just for ****s and giggles.. I still need to add the power wire for the fan realy into the loom. The green and tan wires are the head light and high beam leads that Ill use to power the relays. I wired in the choke realy and got it powered up.
Heres the drivers side.. the blinkers and markers will come in from this side.
and before the flaming starts I still need to make the cover for the hole where the old panel was.
Heres the "new" seats from Keith
and fancy soft door from Brian.
Little bits I guess.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #7 of 7 Old 07-15-2013, 09:45 AM
jsawduste
2006 YJ Wrangler
Ahhh, you are going to wire that alternator up a bit better, right ?
