Quantcast Cleaning up the Engine. . . - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Cleaning up the Engine. . .
Old 11-05-2008, 02:20 AM   #1
chocflip201
Starting a new crawler project, starting by cleanin up the engine a little bit, making it a little more easy on the eye, and fixing any leaks etc..
Pulled out!
Pulled off Intake manifold and Exhast.
Oxidized Exhaust.
chocflip201 is offline   Reply With Quote
Old 11-05-2008, 02:23 AM   #2
chocflip201
Oil fumes plugging up all the pores in the cast aluminum!
Eugh. . no wonder why I was having a hard time passing last emission tests.
Dirty Throttle Body.
Old 11-05-2008, 02:29 AM   #3
chocflip201
Sand Blasted and Ceramic Coated Exhaust
Cleaned and Dirty Injectors
All Injectors cleaned and fuel rail all shiny!
Old 11-05-2008, 02:41 AM   #4
chocflip201
Exhaust wrapped in heat tape!
Vapor Lock heat shield cleaned up! (Halfway done- before and after)
Intake manifold sand blasted and clear coated
Throttle body all cleaned up.
Old 11-05-2008, 06:38 AM   #5
RobsYJeep
1987 YJ Wrangler
holy crap it's looking GREAT!!!!
My only concern is that header wrap usually promotes pre-mature rot in exhaust headers if the wrap gets wet, have you treated the wrap with the high temp sealant?
RobsYJeep is offline   Reply With Quote
Old 11-05-2008, 09:50 AM   #6
sebastian22
Go Kings Go!
sebastian22's Avatar
Wanna come by my house when you're done?
Great job!
sebastian22 is offline   Reply With Quote
Old 11-05-2008, 09:55 AM   #7
AthruC
Awesome job w/ the ceramic coat and heat wrap. I'd imagine that wrap will get awfully dirty, awfully fast
If you don't mind me asking, did you ship the manifold out, or did you coat/bake it yourself? How much did it set you back? I know enough people who wouldn't do this on their turbocharged sports cars, let alone crawler!
AthruC is offline   Reply With Quote
Old 11-05-2008, 11:19 AM   #8
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
Wow, nice clean-up work. You're right - much nicer on the eyes.
Joe Dillard is offline   Reply With Quote
Old 11-05-2008, 11:36 AM   #9
chocflip201
I actually submitted a Write-Up last night on coating and wrapping the headers. - Exhaust Wrap How To I just finished the wrapping last night so it was still wet from the installation process but yes I did purchase a High Tempurature Silicone Sealant that I will spray and bake on the wrapping either today or tomorrow.
Old 11-05-2008, 11:42 AM   #10
chocflip201
I have access to a sandblaster, and springing for a place like High-Performance Coatings to ceramic coat my headers just wasn't in my budget, so I just bought the do-it-yourself kit from my local auto parts store, sand blasted the header, applied the coating in my garage, and paid a local Powdercoater $20 to bake the ceramic coating per instruction of the can. All in all with the ceramic coating, the pipe wrap, and paying the powdercoater I was into it about $60 and 2 days worth of work (powdercoaters took the header overnight) I submitted a write-up of the complete process and time breakdown, and I bought some silicone spray to spray on the wrapping to aid against staining, fading, and fraying/falling apart. Exhaust Wrap How to
Old 11-05-2008, 11:48 AM   #11
chocflip201
Yeah I owe all the aluminum cleaning up to the "Eagle One" brand cleaner. Their "Mag and Alloy Etching Wheel Cleaner" made clean-up a breeze! I actually used it on the intake manifold before sandblasting it and It was turning out great I just couldn't get in all the tight spots and crevaces to make it look a uniform shine so I settled to have it blasted. The sand-blaster that I have access to is 40 grit, and I thought it would be way too corrosive (this blaster is huge, it feeds sand through a 2" diameter tube) and so I paid a local hot rod shop to use some 120 grit sand. and although it made it a nice uniform color, it did dull the aluminum quite a bit, and then he advised me spray a clear coat on it, (I used a special clear coat made for aluminum rims) to help keep the oil fumes from clogging up the pores again, this brought back some of the shine to the manifold but still not like before. Oh well I'm overall pleased.
Old 11-05-2008, 11:55 AM   #12
Opihi59
from here it gets rough
Opihi59's Avatar
Good Lord!! That's a lotta work.......keep the pictures coming.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm
My Boy Scout Troop site: http://t-304.blogspot.com/
Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done.
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Opihi59 is offline   Reply With Quote
Old 11-05-2008, 12:00 PM   #13
chocflip201
Yeah ha it seems like a lot of work especially for a rock crawler. But after my last crawler I realized my next one was going to be perfect how I want it and emaculate. And I'm hoping its all going to pay off in the end. Plus this crawler is going to be 100% street legal as compared to my last one which I dont think a single thing on it was legal, so I will be doing this one 110% in every detail.
Old 11-05-2008, 02:12 PM   #14
provinT13
wow thats turning out great.
2 Hands Working Do More Than 1000 Hands Praying
94 YJ Build
99 TJ Build
provinT13 is offline   Reply With Quote
Old 11-05-2008, 02:39 PM   #15
pat8942
Nice Job!
Aren't you the least bit curious as to why the injectors were so oil soaked?
I've torn down a lot of engines and I don't think I've ever seen injectors as dirty as yours were.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline   Reply With Quote
Glock Forum
