Is a Class II hitch with two bolts in frame safe? - JeepForum.com
post #1 of 4 Old 05-06-2010, 07:20 PM Thread Starter
sprowley
I can get a brand new never used class II hitch from a TJ owner, with the ball, for $50. Trouble is, this style has two bolt holes underneath the frame like the YJ but also two tabs that are supposed to bolt roughly where the rear shackles do. Obviously this isn't going to work.
NOW I could just cut the tabs off, and go with the two frame bolts on the bottom. Those are pretty beefy bolts, I highly doubt I could get them to sheer if I didn't violate "class II" weight ratings. But I'm not sure. I could weld it on but I'd like a better bumper/tire carrier later and that seems a little permanent for future changes.
What are your thoughts?
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #2 of 4 Old 05-06-2010, 09:27 PM
AZoriginal
Weld it on and cut it off later. Never skimp on safety. Or let me know where you are driving while pulling a trailer so I can be somewhere else.
Never, Never, Never Give Up
Winston Churchill
AZoriginal is offline
post #3 of 4 Old 05-06-2010, 09:40 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If the other retaining bolts that are used that you are considering completely removing, were not necessary - wouldn't the hitch not have them to begin with?
Don't cut these type corners - that would prove to be completely foolish.
Joe Dillard is offline
post #4 of 4 Old 05-06-2010, 09:58 PM
fitbmxseries1
1987 YJ Wrangler
can you drill more holes in it? otherwise make some tabs that will fit. Ive built a few hitch set ups for all my trucks and i usualy have min of 4 bolts holding it on, On my xj there are 6. otherwise weld it on.
fitbmxseries1 is offline
Is my hitch a class I, II or III? jeep-newbie JK Wrangler Technical Forum 2 03-22-2009 05:44 PM
Rear Frame Rail / Hitch Mount Bolts CheapSunglasses YJ Wrangler Technical Forum 6 10-28-2008 08:18 AM
Class III Hitch dave's jeep TJ Wrangler Technical Forum 3 10-05-2008 04:14 PM
class 3 hitch on a YJ? j_nition YJ Wrangler Technical Forum 8 10-28-2006 01:32 PM
what class hitch kennyb YJ Wrangler Technical Forum 2 10-10-2005 10:12 PM
