CJ to YJ Windshield Frame - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > CJ to YJ Windshield Frame
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 11-10-2006, 02:18 AM   #1
Lcars
Nanners...MMMM..Toasty
Lcars's Avatar
I was wondering if anyone has or knows if a windshield frame from a CJ will fit a YJ?
I know the wiper motor and the dash mounting are different. I plan on using a CJ dash anyways. What are the differances between the two?
<--- I got a big Dancin Nanner
Jeepiki.com - Jeep Encyclopedia
Originally Posted by JungleLarry
THAT'S MY DICK IN YOUR B*TT!
(Edited for content.)
N7GTJ
View my Paddock Pool construction nightmare at http://www.paddockpoolsucks.com/
Lcars is offline   Reply With Quote
Unread 11-10-2006, 08:26 AM   #2
jeepin92yj
i believe everything should be the same, the yj is just a modified cj
[SIZE="5"][B]-Black Betty-[/B][/SIZE]
[SIZE="1"]4.0L 5spd[/SIZE]
[SIZE="1"]Rubicon 4" kit (5" of total lift)[/SIZE]
[SIZE="1"]5/8 Boomerang Shackles[/SIZE]
[SIZE="1"]2" body lift[/SIZE]
[SIZE="1"]35x12.50r15 Mickey Thompson MTZs[/SIZE]
[SIZE="1"]Ford 8.8 Rear with Rugged Ridge diff. cover [/SIZE]
[SIZE="1"]4.88s[/SIZE]
[SIZE="1"]Detroit locker in rear and Lock Right up front[/SIZE]
jeepin92yj is offline   Reply With Quote
Unread 11-10-2006, 08:46 AM   #3
kenny kustom
you will have to do the cj winshield if you do the cj dash, because of the heater ducts. i have cj dash, winshield and front clip. on my yj tub
kenny kustom is offline   Reply With Quote
Unread 11-10-2006, 11:32 AM   #4
Lcars
Lcars's Avatar
Thats what I was looking to do. I like the CJ dash and want to use it in the YJ. Do the door uppers still fit the w/s frame?
N7GTJ
Unread 11-10-2006, 01:19 PM   #5
fratis
fratis's Avatar
i put a fiberglass cj frame on my yj and the width was slightly off. also the plates on the inside wont match up. nothing that cant be overcome.
fratis is offline   Reply With Quote
Unread 11-10-2006, 02:23 PM   #6
kenny kustom
i run full doors and they fit ok
running a full cj body on yj frame is different that just doing front clip
