CJ windshield frame on YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > CJ windshield frame on YJ
New Knuckles Skid Plate at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker Purcha
Unread 10-07-2009, 02:28 AM   #1
coldyj
The windshield frame on my YJ is in bad shape. I work with a guy that has a CJ and noticed tonight that it doesn't have the 2 ridges at the bottom of the windshield and liked it better than the stock YJ frame. Does anyone know if the windsheild frame from a CJ will fit on a YJ? Is the glass the same also?
coldyj is offline   Reply With Quote
Unread 10-07-2009, 02:42 AM   #2
fratis
fratis's Avatar
it wont be perfect but can be made to fit. i have a fiberglass cj frame and im not sure if it doesnt fit quite right due to the shoddy construction or not. now that i think of it when i had the glass put in, i never told the shop it was a cj frame. im going to assume its the same glass.
fratis is offline   Reply With Quote
Unread 10-07-2009, 05:43 AM   #3
Alfons
The windshield hole in a CJ windshield frame is smaller (and obviously, the glass also) so the whole assembly will fit a YJ but you can't swap just the glass.
Alfons is offline   Reply With Quote
Unread 10-07-2009, 05:52 AM   #4
muddy93
1987 FSJ Wagoneer
the frames will swap, but there are differences. the CJ frame will NOT have the bolt holes for the spreader bars that go from the roll bar to the windshield frame, and the glass is different. I don't know for sure about the hole for the glass being different, but the attachment method for the glass is different. the CJ's use a rubber gaskt that goes inside the windshield frame hole, and holds the glass. on the YJ's, the glass is glued into the frame(on the metal, on top of where the CJ gasket would go), and then a "trim gasket" is placed over the glass.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline   Reply With Quote
Unread 10-07-2009, 06:04 AM   #5
Hylke
Hylke's Avatar
1978 CJ7
In addition: the hole for the holddown knobs won't line up. And the wiper parts of a YJ and CJ are different.
Hylke is offline   Reply With Quote
Unread 10-07-2009, 08:30 AM   #6
Carolinarednek
I was always told that the windshields in YJ's are ALOT thicker than CJ's. Of course, the guy that told me that was trying to sell me another frame for mine when I was looking at a CJ frame for mine. I ended up going back with a YJ frame.
1995 YJ Low output 2.5, Auto. Overall P.O.S.
/_ l__\____\
l --\__l---[]lllll[]
(o))-o-(o))-o-(o))
Carolinarednek is offline   Reply With Quote
Unread 10-07-2009, 09:18 AM   #7
jbolty
ISO 9001 Compliant
jbolty's Avatar
Defroster vents are different too, but as stated it can be made to work. I just used a CJ cowl seal on my YJ and it actually fit better than the original.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
