CJ vs YJ TF999 - JeepForum.com
post #1 of 24 Old 01-11-2010, 09:13 AM Thread Starter
VACJ5
CJ vs YJ TF999
I am still trying to get a replacement TF999 for my YJ... I found a great deal on a rebuilt 999 from a CJ... are there any differences?
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #2 of 24 Old 01-11-2010, 12:19 PM Thread Starter
VACJ5
Or how about... are the bolt patterns for transmission bellhousing on the 4.2 and 4.0 the same?
VACJ5 is offline
post #3 of 24 Old 01-11-2010, 01:23 PM
Why J?
Why J?'s Avatar
Same tranny, no differences.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #4 of 24 Old 01-11-2010, 02:31 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Lock up torque converter?
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #5 of 24 Old 01-11-2010, 02:40 PM
Why J?
Why J?'s Avatar
no- not in Cj's and older Yj's until 92.
May need to swap bell housings. I don't remember if the Cj had a hole for the CPS or not.
Everything you need to know about the 999.
http://www.4wdandsportutility.com/te...ild/index.html
Why J? is offline
post #6 of 24 Old 01-11-2010, 02:54 PM
ctm
Some CJs did have a lock up TC. Mine does (84). I just rebuilt the tranny so I am sure. It is a mechanical lock up though, not electrical. No solenoid.
CJs did not have a hole for a CPS.
ctm is offline
post #7 of 24 Old 01-11-2010, 04:41 PM Thread Starter
VACJ5
I don't currently have a lock up converter in my 91... So the only difference is that there is no hole for the cps? Is there anyway around that other than swapping bellhousings? I wanted to buy this one to try and avoid completely rebuilding one... but if I have to swap everything over to the other bellhousing, kinda eliminates the point.
VACJ5 is offline
post #8 of 24 Old 01-11-2010, 07:18 PM Thread Starter
VACJ5
Okay, so I have heard about this Hensco kit... But I can't find it for sale online anywhere, if I could it is supposedly 370 dollars, and it relocates my cps. I have seen on other sites where people had a bracket and drilled a hole in the bellhousing... called it good.
Can anyone help me locate a hensco kit or tell me about drilling the bellhousing?
VACJ5 is offline
post #9 of 24 Old 01-11-2010, 08:03 PM
Why J?
Why J?'s Avatar
Rebuilding the tf999 is just about as simple as it gets.
Why J? is offline
post #10 of 24 Old 01-11-2010, 08:32 PM
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Avatar
It's Hesco
Hesco Inc. - High Performance Engine Service
This is the part # you supposedly need HES9199ED but it's not listed on their site. Also it appears to be for 91-03 4.0L. You should give them a call in the morning.
Advance Adapters also has a kit. 91-96 4.0L
716012-C | Engine & Transmission Conversion Adapters - Advance Adapters
I hope that helps you.
ChicagoYJ is offline
post #11 of 24 Old 01-12-2010, 04:37 AM
ctm
on the tf999 there is no 'swap' bellhousings...it's part of the tranny, not bolted on like a manual tranny.
ctm is offline
post #12 of 24 Old 01-12-2010, 05:06 AM
YJBlues
YJBlues's Avatar
Honestly, it doesn't take much more mechanical knowlege to rebuild one of those trannies than it takes to get one out of the jeep and replace it correctly. Much cheaper, and you have the assurance of everything that needs replaced, was replaced. OR a trans thats been removed is much cheaper to have rebuilt than one they have to take out, call around. All of this is cheaper than buying another one and rigging up a cps.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #13 of 24 Old 01-12-2010, 05:23 AM Thread Starter
VACJ5
Well hell... I have a spare TF999 laying in the shop... looks like I will be investing in a rebuild kit...
here goes nothing!
VACJ5 is offline
post #14 of 24 Old 01-12-2010, 07:32 AM
dream911tommy
just went through this a few months ago, u need a tranny from a 91-93 they came with cps sensor in bellhousing early yj (non fuel injected) and cj obviously didnt have this... they are hard to find to say the least..
04 tj columbia 35s a small lift and beer
3 yjs, one left thats a long 4link project 2 sold.
86 911 carrera too much stuff to list and alot closer to the ground
dream911tommy is offline
post #15 of 24 Old 01-12-2010, 07:34 AM
Why J?
Why J?'s Avatar
That's right.............. sorry it's been some time since i worked on one of these.
Why J? is offline
Visually tell TF999 or AW4 mmmkay325 YJ Wrangler Technical Forum 9 04-06-2009 05:16 AM
chevy 350 behind TF999 JJ Jeep YJ Wrangler Technical Forum 0 05-16-2008 06:02 PM
Will a AMC 318 fit onto TF999??? Kimoscout YJ Wrangler Technical Forum 4 04-13-2006 08:16 AM
Tf999 COJAM YJ Wrangler Technical Forum 0 11-16-2005 11:30 AM
Going from AX to TF999 what am I in for? BackRoadJPin YJ Wrangler Technical Forum 7 08-22-2005 10:47 AM
