CJ tailgate on a YJ - JeepForum.com
post #1 of 15 Old 11-28-2005, 05:35 PM Thread Starter
dt's YJ
CJ tailgate on a YJ
Age old story, my tailgate hinges ripped the tailgate on my YJ from carrying a 33x9,5 spare on the OEM tire carrier. I know I need a swing away or this will keep happening, but most importantly, I need a new tailgate. I was thinking of the conversion from the side hinges to the bottom hinges, CJ style. I'm a square headlight kinda guy, but I like the idea of a pickup truck style tailgate. Will a CJ tailgate physically fit in the opening of a YJ? I know I will have to do some customizing to make it "CJ style", but can I use a CJ tailgate or do I need a YJ or TJ Gate?
dt's YJ is offline
post #2 of 15 Old 11-28-2005, 08:45 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
first of the month while in moab, I was talking about doing this very thing as well.
I hate opening the rear swing away tail gate and having crap fall all over the place.
I CJ7 fold down tailgate would be far more ideal IMHO, it becomes a make shift work surface, as well as a quick bench to sit on while taking a trail break, etc.
Post up here if you have seen this done or come across any write ups.
Back Road Jeepin
BackRoadJPin is offline
post #3 of 15 Old 11-28-2005, 09:28 PM
mYJ
There is a member on here that has done the swap, can't remember who though. I've been planning this as well but there are some issues to deal with. First you will need to put a bracing behind the body where the hinges would be located under the gate. You will also need to get a CJ latching mechanism to keep the gate closed and you will lose the ability to lock the gate as on a YJ. You will have some top issues as the the soft/hard tops on YJs are slightly different where the gate closes against them. You will have to deal with the spare as well with a swinger on the bumper or put it in the bed as I've done. As said, I will be doing this in the spring because having a "real" tailgate that lays down will be cool not to mention having the Jeep stamped in the back.
-Jeffrey-
92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.
Black JeepClub V2.0 #33 - Me & Roy
mYJ is offline
post #4 of 15 Old 11-28-2005, 09:36 PM
TellyDSP
Poland and PPV!!!!
look for threads started by "superjoe". he has a nice writeup
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #5 of 15 Old 11-28-2005, 09:58 PM
BackRoadJPin
1995 Wrangler
I think some one with wicked fab skills should convert the YJ gate to fold down, still utilizing the same latch/release system to maintian securtiy, and have them cool tailgate cables like on the full size trucks.
Back Road Jeepin
post #6 of 15 Old 11-29-2005, 01:07 AM
Stangman516
yep, superjoe did that on his YJ i'm sure he'll post in here eventually.
'95 Mustang GT
'91 YJ 4.0L
/l ,[____],
l---L--?lllllll?-
()_) ()_)----)_)
White Jeep club member #40
Stangman516 is offline
post #7 of 15 Old 11-29-2005, 06:03 AM
TellyDSP
Poland and PPV!!!!
here's the one I was referring to. It was actually started by someone else, but all the pics are gone. Hopefully he'll chime in.
http://www.jeepforum.com/forum/showt...light=tailgate
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #8 of 15 Old 11-15-2011, 11:59 AM
MotoXguy888
I know it's a little pricey for budget guys like me, but Swagoffroad.com offers two kits for the YJ, one that uses your tailgate with modified latches, cables, and hinges for around 200.00 and another that is just hinges, latch, and cable and you use a CJ tailgate with it. The supposedly hold up to 400lbs which is pretty impressive. I'm thinking about investing in the CJ gate kit for my YJ because I like the old skool JEEP badge on the CJ, just have to find one!
MotoXguy888 is offline
post #9 of 15 Old 11-15-2011, 04:23 PM
Spuznick242
Really? Anyone use the search function ever? Everything on this page has been done before. Including using the stock YJ tailgate (including the factory latch and locks) but made it swing down like the CJ style. Sure it doesnt have the "style" but its going to be covered up by the tire on the swing out carrier that broke the original tailgate anyways so its going to go unseen most of the time. And the drop down tailgate can be done for well under $200, I have a cousin that bought everything he needed and he did it for under $50. I think he used a piece of angle steel to reinforce below the gate, bought a heavy duty set of hinges and then used bolts to hold it all together as well as hold 2 straps to support the gate its self. It's all out there, been done, and usually well covered on how to do.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #10 of 15 Old 11-15-2011, 06:46 PM
scubamc
Hello 2005.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #11 of 15 Old 11-15-2011, 07:45 PM
NHfireLJ
NHfireLJ's Avatar
What he said...Check http://swagoffroad.com/
I looked at his kits and then made my own set up..
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #12 of 15 Old 11-15-2011, 09:05 PM
Nickabis
I bought the swag offroad hinge kit to convert my swing out to a fold down tailgate because it was local to me and it is awesome! I am very pleased with it.
Nickabis is offline
post #13 of 15 Old 11-16-2011, 06:12 AM
xeroid81
jeeperdon did a nice conversion a little while back. I dodn't know if there was a build thread or not. I inquired thru a PM and he kindly responded with the data. Try shooting him a PM or check the archives for his input. Don, your phone's ringing!
xeroid81 is online now
post #14 of 15 Old 11-16-2011, 12:27 PM
NonRubicon
Originally Posted by scubamc View Post
Hello 2005.
NonRubicon is offline
post #15 of 15 Old 11-16-2011, 04:59 PM
E_ROCK
http://www.jeepforum.com/forum/f12/e...build-1151311/
Post #32
Garage Monkey, Wheeling Junkie
E_ROCK is offline
is there a way to make my YJ tailgate like a CJ tailgate? yj_beater51 YJ Wrangler Technical Forum 14 11-29-2009 05:08 PM
Tailgate welds? Tailgate reinforcement? Xtremjeepn JK Wrangler Technical Forum 19 07-10-2009 08:40 PM
Will an Early CJ5 tailgate work in the YJ tailgate opening? JeepsOLot YJ Wrangler Technical Forum 1 02-20-2009 05:59 PM
Tailgate into TRUCK TAILGATE? mxracer513 YJ Wrangler Technical Forum 11 03-13-2008 06:45 PM
Tailgate Bar Atwater10 YJ Wrangler Technical Forum 2 03-30-2004 12:27 PM
