CJ dash swap VSS problems. NEED HELP!! - JeepForum.com
post #1 of 28 Old 01-10-2013, 07:41 AM Thread Starter
moku
OK, So I put a CJ dash in my '95 YJ with a 4.0L engine. Because I wanted to use the mechanical CJ speedometer, I used a speedometer gear pinion housing assembly from a '91 YJ - which provides a connection for a speedometer cable and a 2 wire VSS connection.
The Jeep 4.0L originally had a 3 wire VSS. Using the information from several Jeep forum postings, I connected the WHT/ORG (pin 47) wire and the BLK/LT BLU (pin 4) wire to the new 2 wire connection.
The Jeep starts and runs fine, but dies almost every time I come to a stop. I assume my VSS is not sending the correct signal to the PCM for the idle speed control.
Does anyone know if I used the wrong 2 wires, or if there's a way to fix this?
Thank you in advance!
moku is offline
post #2 of 28 Old 01-10-2013, 07:58 AM
Mark05059
http://www.jeepforum.com/forum/f8/4-...iring-1359348/
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 28 Old 01-10-2013, 07:58 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You're assuming the '95 ECM uses the same pulse config as a '91. The '95 uses a gnd in, and a +8v I believe from the ECM as power, a signal out (orange). I know the +8 part is not critical as I used a simple IGN supplied +12 when I did my swap. I'd look at a '91 FSM to better understand that year VSS system in detail. Dakota Digital (.com) may be able to help too, maybe their SGI-5 unit (I think thats the speedo one, might be the SGI-8).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #4 of 28 Old 01-10-2013, 08:08 AM
Que89YJ
It does use the same VSS signal.
This thread:
http://www.jeepforum.com/forum/f12/c...-15-a-1259852/
Que89YJ is offline
post #5 of 28 Old 01-10-2013, 10:58 AM Thread Starter
moku
Thank you for all of the links. I had read most of those previously and I wired mine based on those posts.
However, I still have the problem.
Any ideas?
moku is offline
post #6 of 28 Old 01-10-2013, 11:20 AM Thread Starter
moku
Oh yea, I also checked the codes and I'm not getting a 15 for the VSS. ??
To clarify, I have the signal and ground hooked to the vss/speedo combo. I had read to leave the 8V power off.
moku is offline
post #7 of 28 Old 01-10-2013, 11:24 AM
Que89YJ
How are you checking the codes without the CEL? What codes do you have?
Que89YJ is offline
post #8 of 28 Old 01-10-2013, 12:54 PM Thread Starter
moku
I wired the check engine light to the "emergency drive" light on the CJ cluster. I have a posi-lok cable installed and didn't care whether or not the shift fork was moved or not.
I got the following codes:
12 - I've disconnected the battery a lot to do wiring
33 - I don't have A/C so I assume it's showing that as an open circuit?
55 - end of codes
moku is offline
post #9 of 28 Old 01-10-2013, 08:11 PM
Why J?
Why J?'s Avatar
Here is a thread that walks throught using the 2 wire:
http://www.cj-8.com/forum/showthread...-4-0-AW4/page6
But I would think that if you hooked it up in correctly then you would get a CEL.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #10 of 28 Old 01-10-2013, 08:41 PM Thread Starter
moku
Awesome, I hadn't seen that sight yet! Thank you. I'll check the wiring tomorrow and see if I have them wired the same. Another forum post mentioned it didn't matter which side the ground was on, and I was a bit curious about it too. I'll post back tomorrow what I find out. Thanks again!
moku is offline
post #11 of 28 Old 01-11-2013, 06:09 PM Thread Starter
moku
I was able to switch the ground and signal wires today, but didn't get a chance to see if it works correctly. I'll report back when I do. Thanks again.
moku is offline
post #12 of 28 Old 01-11-2013, 06:12 PM
Que89YJ
Battery reset it too.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #13 of 28 Old 01-11-2013, 06:14 PM Thread Starter
moku
OK, I disconnected the battery when I rewired it earlier today and haven't hooked it back up yet.
I don't know how the whole VSS system really is supposed to work, so I'm curious what resetting the battery will do?
Hopefully it works though!
moku is offline
post #14 of 28 Old 01-11-2013, 06:16 PM
Que89YJ
Zeros the cal in the ecu and clears any codes set.
Fault codes:
No Start:
Que89YJ is offline
post #15 of 28 Old 01-11-2013, 06:19 PM Thread Starter
moku
What do you mean by "zeros the cal"?
It sounds like you have a good handle on how this works... Which is great!
moku is offline
