cj 7 dash converision - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > cj 7 dash converision
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 03-02-2015, 04:21 PM   #1
jasonjones21
Can i get a list of everything im going to need to do the swap please do not send me to a different fourm please i have the dash, gauges, indicator lights, speedo cable, all the cables for the heater and such, glovebox cover, plastic inside and brand new american autowire wire harness. what else do i need? im planning on not running a dash pad how will i beable to do this thanks
jasonjones21 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 05:21 PM   #2
Luuca
TYPICAL /F12 HOOLIGAN
Luuca's Avatar
reads like you have everything you need, except punctuation and grammar.
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, 1" Shackles, 32" Yoko ATs, 4.10 D30/35 Busted Knuckles
05 LJ Rubicon "Ghost" 4.5" RE, 1.25" BL, 33" Atturo MT, 4.10 D44 F/R Locked
/f12 MOAB 2015
Luuca is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 07:31 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I 'think' the temperature sender is different so you want one to match your new gauge.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 12:17 PM   #4
Rebel442
A CJ fuel gauge is gonna read backwards if you use it with the YJ sending unit. Might wanna lube up the windshield hinges, if its never been down they tend to rust soild. Only way to know for sure you have everything is to just do it. On a side note the entire dash is not needed for the Jeep to run and drive.
Drove it around for a few days like this.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline   Reply With Quote Quick reply to this message
