Cigarette Lighter Doesn't Work - JeepForum.com
post #1 of 3 Old 06-02-2010, 12:20 PM Thread Starter
el scorcho
The cigarette lighter had some light corrosion; I cleaned it as best I could; there's still a bit of rust in the center back. Both wires are plugged in. No cell phone car chargers work, but I haven't tried an actual cigarette lighter.
It's the only electrical problem I have in the dash. I don't know if the AC (where the cigarette is located) was factory or aftermarket. One lead is pruple/white and the other black. I followed them back into the wiring harness where they disappear into the black sheath, then (I think) out through the firewall. All the fuses are good. Any suggestions.
Thanks in advance.
el scorcho is offline
post #2 of 3 Old 06-02-2010, 12:30 PM
pasinbuy
First check the wires to see if you have a hot and ground. If so just replace the cigerate lighter input.
pasinbuy is offline
post #3 of 3 Old 06-02-2010, 01:18 PM
Que89YJ
Power should be in the fuse block at your dirivers feet. Check for a blown fuse.
Que89YJ is offline
air conditioning , electrical , wiring
Cigarette lighter 97 tj doesn’t work johnsoncr TJ Wrangler Technical Forum 11 01-26-2012 11:59 AM
Cigarette Lighter doesnt work, Radio Cuts out and windshield wipers fail 94YJTech YJ Wrangler Technical Forum 1 08-22-2009 10:00 PM
Cigarette lighter jump-start gadget - doesn't work on 2000 TJ? BaaBaa TJ Wrangler Technical Forum 28 06-13-2006 04:04 PM
cigarette lighter mkalcevic TJ Wrangler Technical Forum 13 06-05-2006 05:44 AM
cigarette lighter,never been used but dosen't work, any suggestions? illumin8em TJ Wrangler Technical Forum 4 09-17-2003 07:58 AM
