Cig Lighter Not Functioning? - JeepForum.com
post #1 of 15 Old 11-23-2011, 11:52 PM Thread Starter
Shoelessboi
Okay my fellow jeepers. I've been slowly putting my jeep together to where it will satisfy my jeeping needs. I've came across my cigarette outlet. It is currently not working. Any suggestions to get it going? I'm going to try getting a new fuse on black friday due to thanksgiving. Anyone got any ideas? Thanks!
Shoelessboi is offline
post #2 of 15 Old 11-23-2011, 11:59 PM
jeepnbrett
Do you have a test light? Your first step is to find out if power is getting to the lighter...
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #3 of 15 Old 11-24-2011, 12:55 AM Thread Starter
Shoelessboi
I might possibly have it. I stay at the gf's and her dad usually helps me with all my jeep issues. I planned on asking him the day after thanksgiving since he works 2 jobs and hopefully can get this thing going so i could have a second heater running this winter.
post #4 of 15 Old 11-24-2011, 01:03 AM
ClarkRCC
mine went out and it puzzled me because it was on the same fuze as the cruse control, which my jeep doesnt have
Just keep going till it sounds expensive
ClarkRCC is offline
post #5 of 15 Old 11-24-2011, 01:12 AM Thread Starter
Shoelessboi
I'm hoping its just going to be like a fuse swap.. but my jeep problems are never simple :P ill just find me a cigarette receptacle just to be safe
post #6 of 15 Old 11-24-2011, 02:00 AM
ads
check that the live connector to the back of the lighter is attached - its a push on connector that connects to a pin.
Mine has fallen off before - gave it a squeeze with some pliers last time I put it back on and it seems pretty secure now
1995 YJ - mostly stock at current. 31" Procomp AT, rebuilt stock springs with added leaf (2.5" lift), OME shocks & stabiliser, 20gal tank mod, air box de-restricted, afe wet filter, soundbar, new distributor/rotor & stuff, TBS.
ads is offline
post #7 of 15 Old 11-24-2011, 05:58 AM
Mark05059
why do you need a second heater? my heater will drive you out of the seat even with no back window and a soft top?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 15 Old 11-24-2011, 06:05 AM
reeves_yj_88
My wife has a 95 yj that blows heat like the sun, I have an 88 yj that blows heat like the dark side of the moon...
I thought it was common knowledge, you don't buy a YJ because you're broke... You go broke because you bought a YJ!
reeves_yj_88 is offline
post #9 of 15 Old 11-24-2011, 06:49 AM
DAVE4273
I keep a fire extinguisher in the jeep during the winter and wear fire retardent socks....you know, just in case.
David
DAVE4273 is offline
post #10 of 15 Old 11-24-2011, 07:39 AM
Mark05059
then you need to fix your 88
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #11 of 15 Old 11-24-2011, 07:46 AM
reeves_yj_88
Couldn't agree more. Just bought it for $400 a week ago, running and driving. Other things require attention, but the heat is definitely on the list.
post #12 of 15 Old 11-24-2011, 07:50 AM
Burlbook48
Trial By Trail
Burlbook48's Avatar
Shoelessboi, is the key on? The cig lighter doesn't work on my 95 unless there is power to the lighter. Safety feature, I'm guessing, so it can't short out and cause a fire while you are away from your jeep.
Figured this out while trying to use my 12V floodlight while camping. Thought the dang light was broke until I turned the key on to move the jeep.
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #13 of 15 Old 11-24-2011, 07:51 AM
Billy
Billy's Avatar
this.
lol. I beat myself up so much because I couldnt figure it out. sure enough it wasnt "plugged in" haha
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #14 of 15 Old 11-24-2011, 10:17 AM Thread Starter
Shoelessboi
Lol i just messed with it a little bit and no luck.. Ill have to figure out how the receptacle comes off or i have to find a way to get under to see it all more. I seen the green/white wire that comes out of the back was still attached just didnt push on it or nothing to the receptacle yet.
And my heater works.. but the little heater i have that plugs in the cig lighter i use to use works waaaaaay better.
post #15 of 15 Old 11-25-2011, 02:39 PM Thread Starter
Shoelessboi
I just installed a 2 12v outlet up and its all better now.
94 YJ 4WD Not Functioning BalooNY YJ Wrangler Technical Forum 6 06-25-2011 10:33 AM
Fog lights.... Not functioning! MikeyJ TJ Wrangler Technical Forum 13 10-30-2010 06:22 PM
Top Two Speeds of Fan not Functioning!!! jlangs TJ Wrangler Technical Forum 11 08-22-2008 10:41 AM
Non functioning Speedometer secondsacker YJ Wrangler Technical Forum 8 02-21-2006 01:37 PM
Light not Functioning toeknee24 TJ Wrangler Technical Forum 4 08-11-2005 12:43 AM
