chugy idle/knocking only under acceleration? - JeepForum.com
post #1 of 3 Old 04-23-2011, 10:57 AM Thread Starter
jeepchronicles
1987 YJ Wrangler
Ok guys, so i recently bought a 1987 wrangler 6cyl with 156,0000. The other day i replaced the alternator and belt, immediately after i took for a test drive and now i have almost a knocking sound (fairly loud) under acceleration. while idling no ticking of knocking. if i rev the motor in idle no ticking or knocking(no difference between hot or cold idle). But in idle it doesn't seem to be running smooth(kinda chugy), almost like one cylinder isn't firing. So i replaced the cap, rotor, wires, and plugs figuring this had to be the problem. this gave me more power but problem still remains.
when i first bought it 2 weeks ago it did have some ticking which i am not concerned with(normal sound). when i drive i can hear the ticking and this knocking as two different sounds.
Does anyone know what this could be? all the other ticking/knocking threads sounds like you can hear it at idle.
jeepchronicles is offline
post #2 of 3 Old 04-23-2011, 02:04 PM Thread Starter
jeepchronicles
1987 YJ Wrangler
ok so i messed with the timing a little this morning and it didnt seem to change much. next i tried the trick of removing the fan belt, and that didnt change anything. i do notice that it is burning some oil.
Any and all help will be appreciated
post #3 of 3 Old 05-04-2011, 11:27 PM Thread Starter
jeepchronicles
1987 YJ Wrangler
Really no replies i thought this was a jeep forum?
Rough Idle and Acceleration...Sometimes a1lane TJ Wrangler Technical Forum 2 08-19-2010 01:41 AM
Knocking on Acceleration Eric554 TJ Wrangler Technical Forum 7 11-17-2009 12:14 AM
2.5l ac blows only at idle/low acceleration born2trod TJ Wrangler Technical Forum 4 06-02-2009 02:06 AM
knocking under acceleration mat25542 TJ Wrangler Technical Forum 1 07-20-2005 02:17 PM
Idle/Acceleration problems jeepcostarica YJ Wrangler Technical Forum 9 01-09-2005 09:26 PM
