Chromo shaft install questions - JeepForum.com
post #1 of 6 Old 05-16-2010, 12:37 PM Thread Starter
Toms87
1987 YJ Wrangler
I'm just about ready to order some chromo shafts for my D30 and have a couple questions. I know when installing you need to install new seals which includes the ones in the diff. Aside from taking everything apart and doing the seals, is there anything else I need to do or is this a bolt on kinda job past that?
Also the sites I'm looking at say "you NEED a vacuum block off plate," but my vacuum motor is still there but sealed up with silicone. Are these guys just trying to make more money or is that a legitimate concern?
Here are the particular ones I'm 99% sure I'm getting
Nitro Chromoly Shafts - Front - Dana 30
Thanks
Toms87 is offline
post #2 of 6 Old 05-16-2010, 02:03 PM
4bangerYJ
That kit among others replaces the 2 piece axle on the pass side with a TJ/XJ style one piece. So the vacumme motor will not be used. So you will need a block off plate.
4bangerYJ is offline
post #3 of 6 Old 05-16-2010, 02:09 PM Thread Starter
Toms87
1987 YJ Wrangler
I know the vac motor isn't used, but I'm not using it now either. I just have the shift collar thing locked in place. So basically I'm already running a 1 piece shaft. With that in mind, is a plate still a necessity?
Toms87 is offline
post #4 of 6 Old 05-16-2010, 02:21 PM
MLJeeper
MLJeeper's Avatar
did you take out the shift fork? Remove that and it could be used as the cover.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 6 Old 05-16-2010, 06:04 PM Thread Starter
Toms87
1987 YJ Wrangler
I believe the shift fork is still installed. I can't remember exactly because it was 2 years ago when it was done. Just take it out, keep the assembly sealed and it will work just as good as a plate?
Toms87 is offline
post #6 of 6 Old 05-16-2010, 06:07 PM
MoparFreak69
You can remove the fork off the rod and then yes, just install it back as a plate and be done with that.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
Questions about chromo axle shafts Alex74012 TJ Wrangler Technical Forum 9 04-20-2010 02:02 PM
Superior Chromo D30 (30 Spline)/D44 (35 Spline) Axle Shaft P/N's??? SuperWade2 TJ Wrangler Technical Forum 2 01-02-2010 08:24 AM
d30 chromo shafts jboy416 TJ Wrangler Technical Forum 8 01-12-2009 10:41 AM
HP Super30 VS LP chromo 30 RockRodHooligan TJ Wrangler Technical Forum 3 11-10-2008 04:40 AM
Aussie/Chromo shaft install in D30... darioc YJ Wrangler Technical Forum 7 07-14-2008 06:52 AM
