choke/ linkage stuk please help mates! - JeepForum.com
post #1 of 1 Old 04-27-2010, 06:43 PM Thread Starter
lidlitalian
1987 YJ Wrangler
87 4.2 yj weber 32/36
newest annoyance from heap:
noticed recently that when I first start jeep, when i first press the peddle down for that initial rev,then tap the peddle to get it back down) not sure what you call that process, but I noticed it wasnt the rpm level it usually is. very low, almost stall, sometimes does.
So,
Poked around behind Weber 32/36 and noticed the throttle linkage (the one im guessing makes the initial startup) was stuck, not touching the idle screw. the idles is stuck now at around 1100rmp's.
jeep runs like a sh-t bum.
please advise,
thx!
lidlitalian is offline
Can I convert a weber 32/36 electric choke to manual choke? jake42 YJ Wrangler Technical Forum 2 07-19-2011 05:14 PM
Weber Electric choke to Manual Choke? smitkev2 YJ Wrangler Technical Forum 7 10-03-2009 08:12 AM
AA linkage bracket/ linkage adjustment? Wrangler11 TJ Wrangler Technical Forum 1 06-01-2007 07:56 PM
pics of choke-side linkage diesel158 YJ Wrangler Technical Forum 5 12-01-2005 02:08 PM
Choke on 89 4.2 bigwheels89 YJ Wrangler Technical Forum 1 10-17-2004 06:49 AM
