chirping noise in engine. 94 wrangler 4cyl HELP!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > chirping noise in engine. 94 wrangler 4cyl HELP!!!
AMP Research Powersteps - A Morris 4x4 Center PromotionCrawler Conceptz at JeepHut.comTime To Save On Yukon Lockers!
Unread 08-16-2009, 01:49 AM   #1
jpringles
there is a chirping noise in the engine of my 94 jeep wrangler. i usually notice it after it warms up. my power steering pump is going out at well could that be the same problem?
jpringles is offline   Reply With Quote Quick reply to this message
Unread 08-16-2009, 01:54 AM   #2
DriveTooMuch
Chirping noises. Could be the same problem. I had to replace my idler pulley, that was the pulley that the fan belt rides on. The bearing used to chirp before it went bad. When it warms up, well, it could just be your fan belt is not tight enough.
DriveTooMuch is offline   Reply With Quote Quick reply to this message
Unread 08-16-2009, 01:58 AM   #3
jpringles
well there is town different noises for that the regular chirping but the power steering noise is more of a wining. and when i turn the wheel it idles very low and sounds like it's going to die... so i dont really know if it is the same problem?
Unread 08-16-2009, 02:34 AM   #4
Exparrot
The chirping could be the water pump too.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline   Reply With Quote Quick reply to this message
Unread 08-16-2009, 06:59 AM   #5
dodger889
OK Here is old fashion way of finding a noise and where it is. You can use a hose, wooden dowel or a long screw driver. Put one end of your listening device to your engine close to where you think the noise is coming from ( watch for moving parts). Listen on the other end. When you hear the noise louder at one point you have found your part or location of said sound. This takes out the guessing which part is bad. Saves you time and money.
Now yes the have a stethoscope that is made for doing the something. But I'm cheap if I have something in hand why buy something that will work.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2009, 07:05 AM   #6
kalik99
I had the same problem and mine was the alternator pulley which was sitting slightly too far forward. You could try isolating the noise by individually spraying the pulleys with T9 untill it stops, when it does that is the pulley that is making the noise.
kalik99 is offline   Reply With Quote Quick reply to this message
