Chevy Small block swap update - JeepForum.com
post #1 of 7 Old 01-09-2003, 12:25 PM Thread Starter
Atropine
Atropine's Avatar
Well heres how the chevy swap is going right now:
Motor Chevy Small Block $250.00
Motor Mounts Advance Adapters $140.64
Radiator 3 core center needed
Turbo 350 Automatic TH350 $184.00
Tranny Master rebuild kit $90.99
Transmission cooler needed
Transfer case adapter kit $475.00
Pulley assembly needed
Fan needed
Headers block hugger (nickle plated) $250.75
Exhaust needed
Gasket set (small block) $68.34
EGR valve $54.00
Plugs & Plug Wires needed
Shift Kit needed
Starter needed
Water pump $24.00
Valve Job & Intake $170.00
Air filter Moroso 14 inch $49.90
Hoses/Misc
Flywheel $27.99
SO far I'm up to $1785.61, Im getting close to my original $2K budget... I kinda feel like on Monster garage
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #2 of 7 Old 01-09-2003, 02:06 PM
johny1i
johny1i's Avatar
Just out of curiosity--if it's custom and doesn't have to meet any emissions, why are you putting an EGR on it? I say block that thing off and put the $54 back in your pocket--cha ching! I've had 3 vechicles with Chevy V8s (two 350s, and one 327) and they've never had EGRs.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #3 of 7 Old 01-10-2003, 07:45 AM Thread Starter
Atropine
Atropine's Avatar
When I bought the motor it was blocked off, but the motor is has different heads (57cc) and it has REAL high compression... thats the only reason.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #4 of 7 Old 01-10-2003, 12:46 PM
catfisch
catfisch's Avatar
Atropine is right.. If he doesn't use an EGR valve then he will have to run jet fuel to keep his beast from spark rattaling! An EGR does not effect porformance in the least.. it just cools the chamber to (since there is no longer lead in the fuel to perform this duty) pervent predetintaion........... and we ALL know how our wives and girlfriends feel about predetintaion.. -Cat
"The Jeep is the only real American sports car."
-Enzo Ferrari
-95 YJ
-4.0L High Output
-PowerAid Spacer
-Herculined Tub
-Brand New- AX15
-3'' RoughCountry Sus. Lift
-1.5'' lift-Conferr Shackles
-1'' Body lift
-No rear trackbar
-33x12.50 SuperSport H/T's
-10'' OutlawII Rims
-CB etc
catfisch is offline
post #5 of 7 Old 01-10-2003, 01:16 PM
TexasBlakeWFO
what t-case are you running?
http://www.wfo-offroad.com
TexasBlakeWFO is offline
post #6 of 7 Old 01-10-2003, 01:36 PM
catfisch
catfisch's Avatar
He's running a NP231 with SYE and a Tom woods CV driveshaft
-Enzo Ferrari
-95 YJ
-4.0L High Output
-PowerAid Spacer
-Herculined Tub
-Brand New- AX15
-1'' Body lift
-No rear trackbar
-10'' OutlawII Rims
-CB etc
catfisch is offline
post #7 of 7 Old 11-27-2009, 08:54 PM
LIFTANDTIRES
RUNIN A NP 231 WITH A SYE TOMM WOODS DRIVE SHAFT BUT i HAD TO PUT IN THE 8 DEGREE SHIMS UNDER THE REAR TO MAKE IT LOOK GOOD....ANYONE KNOW HOW TO MAKE THE ALTERNATOR WORK FOR YA ON THE SMALL BLOCK CONVERSION? PRITY MUCH THE ONLY THING HOLDIN ME UP
LIFTANDTIRES is offline
4.0 swap or small block chevy DominicVan91 YJ Wrangler Technical Forum 6 12-13-2009 10:47 PM
chevy small block swap campinkin2 YJ Wrangler Technical Forum 10 07-27-2008 02:50 PM
Best way to run exhaust in chevy small block swap? impboy65 YJ Wrangler Technical Forum 2 02-05-2008 09:07 PM
Small block Chevy Swap la9 TJ Wrangler Technical Forum 3 12-11-2003 11:54 AM
Links for a small block chevy swap? freak4jeeps YJ Wrangler Technical Forum 10 12-11-2002 09:35 PM
