Quantcast chevy 350 tbi operating temperature - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > chevy 350 tbi operating temperature
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 04-25-2009, 08:24 PM   #1
jeep350chevy
1987 YJ Wrangler
I have a small block 350 tbi in my yj, and it has a Chevy nova radiator
with a fixed flex fan on the engine, and a electric fan on the outside of the radiator, this is on a switch not used all the time
I wanted to see what the operating temp should be. it has been 210-220 . and i changed the thermostat last year to a 160, and it still runs hot, I also changed my temp sensor on the head, could my headers be throwing off the temp sensor?
any help would be great, just trying to figure out what my next step should be
I can also get some picks up tomorow
jeep350chevy is offline   Reply With Quote
Old 04-25-2009, 08:48 PM   #2
93jeepyj
I have another car I put a truck 350 in and it ran 180 all day long with a 180 thermostat and a flex fan. I put some underdrive pullies on with a taurus fan to try to pick up a few ponies and it ran just over 200 after that and would get hot in traffic, i'll probably donate the taurus fan to the yj and get something more subtancial for the car. How old is that radiator and water pump ? those are pretty much the heart of the cooling system. I replaced both when we put the motor in the car ( had a 6 cyl before ) The other issue could be the radiator shroud, that really affects how well the fan pull air through the rad. without it you would be fine when moving but when stopped or going slow when wheeling etc that will cause temps to rise.
93jeepyj is offline   Reply With Quote
Old 04-25-2009, 08:51 PM   #3
jeep350chevy
1987 YJ Wrangler
that's one thing it does not have is a radiator shroud
even when the jeep is doing 50 it stays around 210
could i run no thermostat?
Old 04-25-2009, 09:45 PM   #4
Krochus
It would probably run even hotter then because the trermostat also acts as a restriction slowing down the coolant fow enough to allow the radiator to work.
Buy yourself a modern aluminum cored radiator OE style or aftermarket and I'll wager you'll be able to throw the electric fan away. Also as another poster mentioned a shroud is critical to cooling system performance
OE temp gauges are notoriously inaccurate. You may wnat to hook up a scanner and see what the coolant temp sensor for the ECU thinks the temp is. This should be a much much more accurate measurement.
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline   Reply With Quote
Old 04-26-2009, 07:24 AM   #5
jeep350chevy
1987 YJ Wrangler
will it hurt anything with the engine running that hot? should i wrap the headers?
Old 04-26-2009, 08:00 AM   #6
jeep350chevy
1987 YJ Wrangler
[IMG][/IMG]
[IMG][/IMG]
Old 04-26-2009, 08:02 AM   #7
jeep350chevy
1987 YJ Wrangler
[IMG][/IMG]
[IMG][/IMG]
here are a few pictures
Old 04-26-2009, 08:39 AM   #8
Krochus
I think you should remove the electric fan, Electric fans aren't nearly as good at pushing air as they are pulling and with your installation I believe it's only serving as a restriction to your mechanical fan.
Again a shroud is CRITICAL. There likely isn't a thing we can do to help you till you get one
I also would eb skeptical of any temp readings that sender setup gives, it's too close to the header and is too far removed from the cooling passage it should be probing directly into, you should move this sensor. Check the coolant temp with a scanner to find what your temp really is.
Old 04-26-2009, 08:51 AM   #9
yjcrawlr
It needs the shroud and the electric will spin even when it is off.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
yjcrawlr is offline   Reply With Quote
Old 04-26-2009, 08:51 AM   #10
jeep350chevy
1987 YJ Wrangler
ok thanks for the info, how would i go about getting a shroud? any ideas what shroud would work?
I wrapped the header just now, going to see if it changes anything
Old 04-26-2009, 08:54 AM   #11
Krochus
even free spinning it's still slowing down your airflow.
No hotrod I've ever owned with cooling problems was ever helped by adding more fans. If your radiator is big enough and in good working order. You have a good belt driven fan and a shroud you shouldn't need a fan in front of your fan
Old 04-26-2009, 08:57 AM   #12
yjcrawlr
I have the electric in front of mechanical with the shroud and a big winch in the way and still don't overheat not running the electric. I guess I'm lucky.
Old 04-26-2009, 08:59 AM   #13
TxJeepGuy
Junior Member
I don't think wrapping the headers will help as much as it could hurt - a local shop, that has built alot of racing/serious offroad rigs, suggested that I use a plate made to replace the thermostat and play with the size hole drilled in the middle. They suggested to just use a hole saw with approx. a 3/8" drill to start - then just drill the hole out if increased flow was needed. I checked this out with a friend that races on dirt tracks and he indicated that is what he is running. don't know if this will help, but maybe worth a try. I agree with the puller fan comment above.
TxJeepGuy is offline   Reply With Quote
Old 04-26-2009, 09:00 AM   #14
jeep350chevy
1987 YJ Wrangler
the problem is, i don't know what shroud to use
Old 04-26-2009, 09:05 AM   #15
Krochus
you could start with a jeep one.
Glock Forum
