Chevy 10 bolt questions - JeepForum.com
post #1 of 6 Old 08-18-2011, 11:17 AM Thread Starter
Awesome
A buddy has some ten bolt front and rears out of a '73 C10 that he is willing to give me. I can't use the front because it's a passenger drop, but the rear sounds perfect. From what I can find out, it's almost exactly the same thing as a Jeep D44 axle, it's even the right width. The issue here is that it's a six lug axle and I don't want to run two different sets of wheels. I'd rather keep my Jeep wheels on both axles.
What are my options for keeping my stock wheels? Is it worth it to do a ten bolt swap? What kind of locker options do I have with a ten bolt? Same as a D44?
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #2 of 6 Old 08-18-2011, 11:19 AM
JohnnyZJ
not worth it.
do an 8.8 if you want to swap axles. it'll hve same bolt pattern as your front
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 6 Old 08-18-2011, 11:30 AM
zeus87gn
1987 YJ Wrangler
If that's the 8", 10 bolt - I believe you would have to change the axles to get the right bolt pattern to match your front axle. They are strong - I've seen them do 500Hp launches at the strip. Lord only knows if they have been upgraded.
BUT, it's a bit wider than your front D30 by a number of inches.
Keep that in mind before you jump into it.
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #4 of 6 Old 08-18-2011, 11:32 AM Thread Starter
Awesome
Ah yes, I wanted to ask that too... how do I measure the axle? What part of it is 8"? I assume it's called a ten bolt because the diff cover has ten bolts? I have no idea why an 8.8 is called that.
Awesome is offline
post #5 of 6 Old 08-18-2011, 11:35 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Originally Posted by Awesome View Post
Ah yes, I wanted to ask that too... how do I measure the axle? .
wheel mounting surface to wheel mounting surface.
It has an 8.8 inch ring gear.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #6 of 6 Old 08-18-2011, 12:02 PM Thread Starter
Awesome
Okay thanks for the info.
Awesome is offline
chevy 350 bolt up transmissions Ripper3494 YJ Wrangler Technical Forum 11 02-21-2011 11:16 PM
Chevy 10 bolt TXjeepin YJ Wrangler Technical Forum 8 01-16-2011 02:01 PM
chevy 12 bolt rdtj TJ Wrangler Technical Forum 18 09-28-2010 01:51 PM
Chevy bolt pattern Mark455SD YJ Wrangler Technical Forum 2 04-01-2009 10:05 PM
dana 44 and chevy 12 bolt jakerz YJ Wrangler Technical Forum 10 09-30-2007 08:25 PM
