Chev 350 engine swap could use wire info - JeepForum.com
post #1 of 6 Old 08-06-2008, 09:10 PM Thread Starter
strd27
1987 YJ Wrangler
Hi to all, I am very new to your fourm. 1st thread. If some one could help it would save me time. I have a 1987 jeep wrangler it HAD a 258 inline six with a 5 speed tranny behind it. All that has gone by-by she now has a chev 350 it is a 1984 (i had to go 84 because of my state I/M laws) i have a 700R4 tranny and a 241 short shafted transfer case and as of right now I have just come in from setting my Dana 44 under her the rear end is not bolted up yet but she will be this week end. I forgot the 350 is carb not fuel injected. What I have is a **** load of wires from the engine comp if some one could please narrow it down as in color or any other markings. I need the Eng temp, Eng oil and I will need a good wire for the HEI dist then of course the power leaks off the starter if some one could tell me how to find it or MAYBE have a copy of it. Please let me know
strd27 is offline
post #2 of 6 Old 08-06-2008, 09:51 PM
bigredcherokee
Your gonna need this
Chilton Part no 8535
Its got everyting you need to know about your wireing quiestions.
For those of you in Louisiana visit
bigredcherokee is offline
post #3 of 6 Old 08-07-2008, 09:38 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
chilton, haynes, alldata.take your pick.
or you could try to search i guess.....
seriously, not one of us here know what wires you are dealing with. there is no telling what wires have been cut/removed/added/corroded etc etc etc.
cant be that hard though, i put a tbi motor in my junk and got it running!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 6 Old 08-09-2008, 04:12 PM Thread Starter
strd27
1987 YJ Wrangler
Wires are no big deal I was just looking for a short cut. It is easy to find the correct wire for the senders you don't need any manuals I was just hoping some one had the info handy. Thanks
strd27 is offline
post #5 of 6 Old 08-09-2008, 09:50 PM
stu1021
Try this link......http://www.autozone.com/shopping/rep...00c1528008ad56
All the wiring diagrams are on Autozone.com
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #6 of 6 Old 08-10-2008, 06:37 PM
doug_1994
doug_1994's Avatar
I can't help you on the gauges, but all you need is a hot wire to the coil. I've had old beaters, with every wire gutted. I just run a toggle, and push button for the start, and flip the toggle for shut down.
Thats if you don't want to go through the ignition. (real big short cut!)
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
Another chev v8 swap Giviner TJ Wrangler Technical Forum 100 01-26-2010 01:48 AM
Chev Gen3 engine swap - info compilation Giviner TJ Wrangler Technical Forum 27 05-12-2009 10:04 AM
Chev V8 Swap? Wallace TJ Wrangler Technical Forum 8 03-12-2007 03:18 AM
Engine swap info jetcracker82 YJ Wrangler Technical Forum 1 10-14-2006 04:30 PM
Chev 4.3L swap dartboy YJ Wrangler Technical Forum 2 04-15-2002 04:09 PM
