check engine light question - JeepForum.com
post #1 of 18 Old 09-10-2009, 11:03 AM Thread Starter
92renegade
I was wondering if the check engine light is supposed to come on when you turn the key on. I have noticed the only light that comes on is the seatbelt light. This is my first jeep so trying to see what the norm should be. I have repaired the ribbon cable for the dash, due to the speedo and dash lights not working. I took my multi meter and tested all the traces and they have continuity.
92renegade is offline
post #2 of 18 Old 09-10-2009, 11:11 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
My '91 CEL light does come on as soon as the key is turned on.
Bulb bad?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 18 Old 09-10-2009, 11:15 AM Thread Starter
92renegade
replaced all bulbs before I found the corroded ribbon cable to be the issue
What light do come on when you turn the key on? What ones stay on during crank?
post #4 of 18 Old 09-10-2009, 11:23 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The display on my '91 is a bit different than your '92 as there were changes made between the years, IIRC.
My CEL is the only one that comes on when the key is turned on (unless the park brake is on) as I have disconnected the seat belt light & the annoying upshift light. I never noticed if it stayed on during cranking or not.
Here is my display held up to the light so all of the indicators are visible.
Max
Mean Max is offline
post #5 of 18 Old 09-10-2009, 11:34 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Okay, I went outside & checked with both my '91 YJ & the wife's '93 YJ.
'91 = Only the CEL light comes on with the key turned on. (as I said I removed the upshift light.)
'93 = Upshift indicator & CEL comes on with key turned on.
On both YJ's the CEL light comes on when the key is on & stays on during cranking if the starter is engaged quickly enough.
On both YJ's the CEL light will eventually go out (in about 15 seconds) if the starter isn't engaged but the key is left on.
Max
Mean Max is offline
post #6 of 18 Old 09-10-2009, 11:49 AM Thread Starter
92renegade
thanks for your quick responses I will double check for some corrosion on the pins on the dash plug
post #7 of 18 Old 09-10-2009, 11:51 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Welcome!
Max
Mean Max is offline
post #8 of 18 Old 01-15-2010, 02:19 PM
southbound
Max, how did you disconnect the seat belt light and the shift light?
The R turn, L turn, hi-beam, check engine and p-brake lights are the only ones that work on my indicator light cluster. I would like all of them to function correctly. And being as those are the most necessary lights, I think the PO of my Jeep disconnected the rest of the lights somehow. I've run into some of his old "projects" from time to time, and then I always have to clean up and repair his work...
I just recently replaced all of the small bulbs in the cluster, so I know it's not just the bulbs being burnt out or the PO removing them. Did he disconnect a ground somewhere or pull a fuse under the dash? All of the connections are clean and free of corrosion (I cleaned them all with a pencil eraser when I removed the cluster). All the ribbons on the circuit board looked great and in pretty good shape, so I'm a little unsure why the lights are not working properly.
Thanks ,
5.7L Hemi TJ Build: http://forum.aev-conversions.com/showthread.php?t=7434
southbound is offline
post #9 of 18 Old 01-15-2010, 02:36 PM
Fhajad
Thanks ,
The seat belt has a plug right behind to the right of the driver seat and goes up into the buckle assembly.
Fhajad is offline
post #10 of 18 Old 01-15-2010, 04:08 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Ditto on the seat belt light/buzzer, and PM sent on the upshift indicator light.
Max
Mean Max is offline
post #11 of 18 Old 01-15-2010, 04:17 PM
dodger889
Up shift light can be just taken out. no llght bulb= no light coming out. LOL
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #12 of 18 Old 01-15-2010, 04:20 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
southbound is looking to get his working again. Apparently, the PO disabled it via the wiring because the bulb is good.
Max
Mean Max is offline
post #13 of 18 Old 01-15-2010, 04:38 PM
dodger889
Opps then pin 54 (orange / black that changes to light green/white) off the ECM should be the one to work with .
post #14 of 18 Old 01-15-2010, 04:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yeah I sent him some info on that, I wasn't aware that it changed from orange/black to light green/white. Where does that happen at?
Thanks!
Max
Mean Max is offline
post #15 of 18 Old 01-15-2010, 04:42 PM
dodger889
I think at the connector at the firewall or at least on a xj wiring diagram does.
Check engine light question agent_J TJ Wrangler Technical Forum 2 08-17-2008 05:43 PM
Question - Check engine light odie6423 TJ Wrangler Technical Forum 3 04-16-2007 05:10 PM
check engine light question romiin YJ Wrangler Technical Forum 3 10-01-2006 09:09 AM
check engine light question c0wby1 TJ Wrangler Technical Forum 1 05-20-2005 06:19 PM
Check engine light question Jim Smyth TJ Wrangler Technical Forum 4 05-20-2005 05:18 AM
