#1 | |
Check Engine Light Does Not Flash
I am having a lot of issues with my Jeep...but right now I am trying to check the codes and I know how to do it however the check engine light IS NOT flashing....what does that mean??
~ Love Rocks ~ |
#2 |
Injanir
Does it light up when you first turn the key to the ON position? If not, the bulb is probably bad.
Lou I have a jeep...and it is modified...I win. Vote January YJ of the Month! (click here) My Dumb Ole' Build Thread Warn M8000 Rebuild Adventure University of Georgia |
#3 |
it lights up and stays on...no flashing
~ Love Rocks ~ |
#4 |
I just recently went through the same thing.
I could not, for the life of me, get the CEL to flash the codes. I even double checked that I had the correct on-off-on-off-on sequence for the key, and still nothing. it turned out that I was going through that key sequence to fast!!!!!! go through the on-off-on-off-on sequence a little slower, and see if that makes a difference. also, there is a bit of a delay between finishing the key sequence and when the light starts to flash.
maroon 1987 Grand Wagoneer. stock for now... |
#5 |
When checking the codes, turn the ignition key to "On" do not go all the way to start. Then turn the key one click back to "Off" do not go all the way back to where the key can be removed, then back to On, Off, and stop at On. Wait 5 seconds, the lamp will then extinguish and begin flashing the codes. I've seen several people do this and not be in the correct positions with the ignition switch, i.e. going all the way back to where the key can be removed.
#6 |
thanks for the advice guys, but I have checked the codes before with no problems. It's possible I was going to fast trying to stay under the 5 sec rule..but I do know how to do and there was no delay the light just stayes on the entire time....oh well another mystery with my Jeep...that's the least of my problems...still won't start.
Have a great day!
~ Love Rocks ~ |
#7 |
UPDATE!! Well, we may NEVER really know what the exact nature of the problem that caused my Jeep to up and die while driving home on a gorgeous Saturday afternoon. We could speculate that is was the fuel pump that went, but perhaps we were wrong, It was defintitely NOT the ECM or PCU so thank goodness there! The problem was most likely the CPS which I did change out, however the guy who replaced my fuel pump inadvertantly wired it backwards causing the unit not to work properly, so the Jeep did not start even after the CPS was replaced.
Last Monday, we fixed the wiring issue on the fuel pump and the Jeep did start and it ran for quite some time as I believe I have reported already...the reason it died the third time around, was not due to anything except some wires that somehow decided to find a nice place to lay which happened to be on my exhaust pipe...and as I am sure you have figured out, the wires melted causing a short thus not allowing my Jeep to start....whew!!! So that is the ending to my Jeep saga, nothing major (except the 4hrs of labor at the mechanic) just a little bit of carelessness and $462.00 out of pocket to fix the problem....actually is was $38 dollars to FIX the problem and $388 to FIND the problem....LOL! Moral of my story...TAKE YOUR TIME!! DON't ASSUME ANYTHING AND CHECK ALL YOUR WIRING NEAR HOT SPOTS FOR SHORTS!! TIME IS MONEY... Take care y'all!! __________________
~ Love Rocks ~ |
#8 | |
In the future though should another problem arise... I strongly suggest keeping the problem contained to one thread. This particular problem encompassed 4 different threads. One thread alone will keep a continuity of the troubleshooting that has been performed and the suggestions that have already been tried. This makes it easier for those trying to help you diagnose the problem. Congrats on getting it fixed! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
