Check engine light on after mudding.. Weird codes - JeepForum.com
post #1 of 6 Old 09-02-2013, 03:15 PM Thread Starter
ibacavergrl
So I have a 93YJ... went mudding and it was fine, came home and parked it. Next day the Check Engine light came on so I didn't drive it, ended up taking my bike out. I did the on off with the ignition to get the codes from the jeep when the check engine light flashed the codes, and I came up with:
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
24** Throttle position sensor input above maximum acceptable voltage.
or Throttle position sensor input below minimum acceptable voltage.
33* An open or shorted condition detected in the A/C clutch relay circuit.
Now I don't have an A/C so im not worried about 33*.... haven't ever had one, but this is the first time my check engine light has ever came on... running crappy... kept wanting to die on me when i tried to pull it out of the driveway and the check engine light comes on soon as I start to drive, not when I turn it on.. was weird...
ANY ideas/suggestions? I don't wanna take it to the shop if its something that I can do myself...
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
ibacavergrl is offline
post #2 of 6 Old 09-02-2013, 05:52 PM
Que89YJ
12 33 & 55 are normal. 24 tps is caused by the tps or the map sensor. Check the vacuum lines to the map and pull and clean the tps. Disconnect the battery for a long 10 count to clear all stored codes.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #3 of 6 Old 09-02-2013, 05:53 PM
Que89YJ
It is easy to fix.
Fault codes:
No Start:
Que89YJ is offline
post #4 of 6 Old 09-02-2013, 06:04 PM Thread Starter
ibacavergrl
ok i appreciate it... ill have to see if that works... i guess i gotta clean off all the mud that is on the engine so that i can see what i am doing...
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
post #5 of 6 Old 09-02-2013, 06:27 PM
WNUNEZJR
I get those some time too but they go away once I turn it off and on.
WNUNEZJR is offline
post #6 of 6 Old 09-02-2013, 06:29 PM
Que89YJ
Yep. You should get electrical grease in all the connectors if you are going to wheel it in water and mud. It keeps the water out.
Fault codes:
No Start:
Que89YJ is offline
