check engine light??? - JeepForum.com
post #1 of 3 Old 04-12-2013, 03:29 AM Thread Starter
skimsurf
I was on my way to work this morning and my check engine light came on. I turned off and then back on and it went off. it then came back on another 20 miles or so down the road. I got to work and turned it off and back on it went off again. and it went out. I checked over everything nothing seemed to be leaking that I could see. I watched the gauges on my way and everything seemed good. but on a 23 yr old jeep it makes me nervous. the motor sounds fine. its a 2.5 with 125k. no knocks or anything. should I be worried?
skimsurf is offline
post #2 of 3 Old 04-12-2013, 04:10 AM
Mark05059
check the code and find out what it is...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 04-12-2013, 05:49 AM
Que89YJ
How to check for fault codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Check the codes. It's really easy. Post what you find. Chances are if it is intermittant that it's O2 or an alternator fault.
Que89YJ is offline
