Cheap trick: Hi Lift Jack mount - JeepForum.com
post #1 of 3 Old 05-09-2002, 05:20 AM Thread Starter
ArmyYJ
I think I stumbled on a cheap & easy way to mount a "48 Hi Lift jack on a YJ:
If you remove the "Bumper-ets" from the rear frame the holes line up perfect with the holes that run along the jack's shaft. You'll have to remove the jack's base so it mounts flat ( I just keep it in my jeep's tool box). I used "3 by 1/2 bolts with wing nuts for easy access to the jack. I wish I had a picture becuase it looks pretty good.
95 YJ 4 Banger
ArmyYJ is offline
post #2 of 3 Old 05-09-2002, 05:55 AM
gifargis
I also have another.. to keep it out of the rain, mud, snow, etc...
I had taken off the rear seat belts.. and coil's.
The hi-lift holders fit perfectly on the inside of the rollbar,(on both sides).. I welded the holders onto the body and placed the hi-lift there...(basically behind the rear seat)
it perfect for any outdoor mess spot.. to keep it clean and out of harms way... for the time you really need it...
See y'll on the trail.
gifargis is offline
post #3 of 3 Old 05-09-2002, 02:06 PM
Kev
Master of the Obvious
Kev's Avatar
You don't have to take the rear seat belts out; I've got my Hi-Lift mounted to the rollbar with exhaust pipe u-bolts above the rear selt belts and haven't had a problem! <img border="0" title="" alt="[Wink]" src="wink.gif" />
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
Hi Lift jack, where to mount MajorDookie YJ Wrangler Technical Forum 12 03-05-2008 10:48 AM
where to mount hi- lift jack and cb ant mount 97_tj JK Wrangler Technical Forum 12 01-21-2008 08:03 PM
where to mount hi- lift jack and cb ant mount 97_tj JK Wrangler Technical Forum 0 01-21-2008 02:29 PM
Hi-Lift Jack Mount?????? Rubi Doo TJ Wrangler Technical Forum 9 01-20-2007 10:09 PM
Got a good cheap fix or trick? New "Cheap trick and fixes" forum for us! Jerry Bransford TJ Wrangler Technical Forum 0 08-21-2004 11:33 PM
