Cheap Reliable Lift? - JeepForum.com
post #1 of 8 Old 03-10-2008, 11:51 PM Thread Starter
RicksYJ
Hey im looking for a 2" lift (or somewhere around there). So it dont require any extra work and its not jacked up to high where my kids cant get in. I want suspension of course new leafs/shocks bolts stuff like that. But I want a reliable one... not 1 that will just level out in a couple years. Anyone know of one?
RicksYJ is offline
post #2 of 8 Old 03-11-2008, 12:12 AM
mdo817
BDS is the way I would go (went), I had a Rough Country,it lasted about a year. The warranty has no fine print, bend it,break it, they will replace it FREE. You can build your own lift on line at there sight. Or if you don't mind a road trip call Southern Offroad in Alpharetta, GA 770-346-7777. They more than likely have the parts in stock. They are actually cheaper than BDS on line and no shipping.
1992 YJ, Project In Work,Frame Off Done, Repainted, Herculined Interior, Back on the road.Self Fab'd front/rear bumpers & tire carrie,MM SE9500,lot's of Susp. 1" BDL,BrandonYJ Boomerangs, 33X10.5 BFG M/T, 4.0 AX-15,8.8 LSD,4.10 Gears, ARB Up Front,P/S Rocker Knockers with slider. 90 YJ now turned into a parts Jeep.
2006 WK 4X4, Wifes Ride (Grandkid hauler)
1995 YJ,4.0, AX-15, Bone Stock Wifes Toy
mdo817 is offline
post #3 of 8 Old 03-11-2008, 12:12 AM
jeepdog5
jeepdog5's Avatar
the 1.5" kit from Black Diamond gets good reviews and my friend has one on his CJ7...i like it a lot.
it's a very middle of the road lift. good balance of quality and price. Couple that with 5/8" lift MORE Boomerang shackles and you've got a pretty good rig that should clear 31" tires.
Black Diamond lift kit on 4wd.com:
http://www.4wd.com/productdetails.as...2&partID=10654
M.O.R.E Boomerang shackles on 4wd.com:
http://www.4wd.com/productdetails.aspx?partID=11915
jeepdog5 is offline
post #4 of 8 Old 03-11-2008, 11:49 PM Thread Starter
RicksYJ
http://www.quadratec.com/products/16300_303.htm
Is the RE Lift good and reliable? I might just go with a 4" lift because I currently am running 32" tires but I drag every now and then on my flare. I think im going to do this RE 4" lift nad go with the TJ Flares. What you guys think? Good for off roading then?
RicksYJ is offline
post #5 of 8 Old 03-12-2008, 05:26 AM
cosminciortan
cosminciortan's Avatar
i went rough country 4.5"
and with the new springs they have, it's pretty much ok
i don't trail much, thew
'95 2.5l red YJ. 35"BFG MTs on 4.5"SKYJACKER lift+ 5/8"Boomerangs, overhauled AX5 (still sucks)
smittybilt flares, bestop softtop and doors, double core aluminum radiator with Flexalite fan, new brakes allround, all poly bushings, armour
cosminciortan is offline
post #6 of 8 Old 03-12-2008, 09:22 AM
veritas4156
1991 MJ Comanche
Anyone know the cheapest place to get a 2" bds lift? I'm trying to find retailers online but all i can find is BDS themselves.
1991 MJ 4.0L AX-15 NP231 ONLY 56K miles
2001 Suzuki SV650S
veritas4156 is offline
post #7 of 8 Old 03-12-2008, 09:44 AM
obsessedjeeper
obsessedjeeper's Avatar
2013 WK
http://www.dc4wd.com/
Keep on Jeepin
95 YJ
98 ZJ
obsessedjeeper is offline
post #8 of 8 Old 03-12-2008, 11:31 AM
lturley
lturley is offline
Cheap 95 YJ lift? rallon YJ Wrangler Technical Forum 20 10-29-2010 11:11 PM
cheap lift highflyer TJ Wrangler Technical Forum 18 06-25-2009 05:18 PM
What is cheapest yet most reliable lift kit? EK91YJ YJ Wrangler Technical Forum 48 07-16-2008 07:42 PM
3" econo lift(cheap suspension lift tips) rivers edge TJ Wrangler Technical Forum 16 09-13-2006 05:57 AM
Cheap way to lift my YJ... Fast Kawasaki YJ Wrangler Technical Forum 8 03-07-2006 10:20 PM
