Cheap And Easy Intake Mod(Write up+Pictures)
#1 | |
Hey everybody Tj here from nisky. So as you might know the weather is pretty rough outside. I figured I keep myself occupied and help the cause by doing a write up.
I have seen a lot of good write ups to help other people and I figured I might as well do one. As easy as it may be. But here it goes anyway. Things you will need: Stock Yj’s (or any jeep for the matter) air box Mesh (optional) Regular head screw driver Screws (small) Wire cutters Pliers (needle nose) And about 20mins of your time. What we will end up doing in this mod will be removing the air condenser and a plate that restricts the amount of air coming into the engine. DISCLAIMER:yes this can be harmful if you decide to cross a river it can suck water into your intake, but other wise you should be ok. First you will need to locate and remove your stock air box. It’s a lot easier to do the work inside. ![]() Once you have removed it bring it inside and basically pull it apart with the tabs (as if you were changing the air filter). ![]() Then you need to locate the condenser, it is the hourglass shaped hole in the front of the air box. ![]() The easiest way to remove it is to push in the tabs with a screwdriver and pull it out. ![]() Once removed this is what the condenser should look like. If what you pulled out if something different…you might want to put it back… ![]() The next part is removing the plate that is on the side of the Stock Yj’s air box. Use the screw driver to pry the plate off. Try to keep it in one piece. ![]() Then you want to cut out a piece of mesh that is the same size as the plate. The reason for this is to just keep any LARGE debris from getting into your air box. ![]() ![]() Then just screw the mesh into the existing holes and you are all done with the mod. Just install it and listen to your engine purr because you just gave it new barks that will surly follow its bite. ![]() Enjoy! tell me what y'all think of my frist write up ![]()
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory" Mostly Stock,With A Few Things My Build Thread Last edited by thetrashman; 12-23-2009 at 07:24 PM.. |
#2 |
The trick has been around awhile, however it makes it easier to suck water into the stock airbox (no more so then an aftermarket intake though). Just a warning to anyone doing this
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife) 1946 CJ2A, 225 V6. mild lift - TIME TESTED 1966 M416 1/4 ton Military Trailer -- WAR TESTED Full Page Club member #004 Green Jeep Club Member #005 |
#3 |
Hi. I am wondering what people think of this as well. I am contemplating trying it. Seems like a great idea and cheap. That with new plugs, and throttle body cleaner, I would think would improve your performance. I have a 1992 YJ 4cyl.
Steven Elliott - Newbie but longtime reader Owner of 1992 Jeep YJ Wrangler S Besttop Softtop, "Don't give up, don't ever give up" Coach Jimmy V |
#4 | ||
haha Quote:
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory" Mostly Stock,With A Few Things My Build Thread |
#5 |
Looks like you live in NY, so you have rough winters. I live in Illinois and have rough winters so was wondering about what the other poster was saying about water getting in. Is that a big issue? Its something I'm really looking at doing. Not being a wrencher, but a lover of interesting ideas, and a newbie, this is a project I think I could do and build some confidence, but don't want to hurt the jeep in the long run. Everything is stock on my jeep right now.
#6 |
Location: Stuart, 30 miles north of West Palm Beach, Florida
I took out the air condenser you were talking about, as well as another restricter piece in the top of the filter box. I thought about doing the Hummer intake mod. In this, you block the front intake, make a hole in the back of the filter box, run a tube/hose into the firewall and up through the top of the cowling just ahead of the windshield. This way, you get around the water issue, as well as getting a cold air intake out of it. Someone did a writeup on it, just search "Hummer intake mod", and it should come up. Great write up!
Jerry ![]()
1992 Jeep "CJ9" (YJ with '78 CJ front clip, '80 CJ Tailgate, Custom CJ Dash with '76 CJ Gauges) AX-15 from a '93 YJ, 2.5" Rancho SL, 5/8" MORE booms, 1" BL, and 33"x10.50" SS TSL's |
#7 | ||
95' Little Red Yj.
#8 |
#9 |
My jeep is a DD, with a little bit of fun in the snow, but nothing crazy. Most of my Jeep is stock, so sounds like this mod would be ok for me. Thanks for the info
Funny reply fratis to the puddle comment.
#10 |
Looks like nice easy mod even I can do however I am currently running just as the pic here shows, no intake front tube. Wasn't there when I purchased the jeep. So will this mod add any more level of water risk then what I already have? Also will it allow anymore air in then what I am getting without the front tube?
Thanks
HanksRide
(Hank is Yellow Lab) He loves it!! 95yj 4.0L, 4" RC Lift, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch 3500 Mile Road Trip With Daughter Daughters 04 TJ Build Thread My-95-YJ Build Thread |
#11 | |
95' Little Red Yj.
#12 |
I have no tube from the front of the air box to the grill. Just a hole in the front of the air box like the pic I quoted has.. Shoot, maybe they are supposed to be that way, but it looks like something is supposed to be there.
HanksRide
#13 | |
You can't teach an old dogma new tricks. |
#14 |
I have a short plastic tube that goes from the airbox to behind the drivers side headlight. Sort of like having a cold air intake. Note I said "sort of like". |
#15 |
Haha yeah I understand I mean doing this mod or anything like it will improve your air flow and will this improve performance
95' Little Red Yj.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
