A cheap but little lift for 31/10.5 - JeepForum.com
post #1 of 6 Old 10-16-2001, 02:05 PM Thread Starter
glm 87 wrangler
Had wide fenders but someone in a parking lot crack one.So I put the stocks back on for now
Found out that every time i round a curve they scrub.So now I want to raise it a little
would a shackle lift help.I dont know about this part.But dont have the funds to spend much on it.I have seen the add a leaf spring set up but still a little pricey for now but maybe later.Any replies would help.
Just in case i do mud slinging more than rock crawling so I dont need much lift Thanks
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #2 of 6 Old 10-16-2001, 02:26 PM
kcmudduck
If you only play in the mud then you could get shackle lifts they are really cheap and would give like 1 1/2 inch lift. They make your approach angle bad but you said you don't play on rocks so you should be fine. look at this http://jcwhitney.com/productnoitem.j...=55069&BQ=jcw2 or if you want you could just do a body lift. and if you want it really cheap go with the hockey pucks.
95 Yj with "stuff"
kcmudduck is offline
post #3 of 6 Old 10-16-2001, 02:38 PM Thread Starter
glm 87 wrangler
thanks that what i needed to know I did not know if when you do a shackle lift if you had
to lift the susp.also.THANKS THATS WHAT I WILL DO.LIKE THIS FORUM ALOT..
post #4 of 6 Old 10-16-2001, 02:59 PM
dennisuello
dennisuello's Avatar
do a really mild shackle lift (no more than 1 inch lift) and a 1 inch body lift. that will have enough clearance for 31s
dennisuello is offline
post #5 of 6 Old 10-16-2001, 04:23 PM Thread Starter
glm 87 wrangler
Just to make sure if i do the lift lets say
1 1/2 would i need to buy longer shocks or will stock work fine,need new shocks any way
will pay the price for that.THANKS AGAIN FOR THE REPLYS
post #6 of 6 Old 10-26-2001, 09:41 AM
jeepinkid
forget the lift i run 31's on my 92 yj just fine and have mad articulaction with very little rub
jeepinkid is offline
Looking for cheap 2in lift miked2905 JK Wrangler Technical Forum 9 11-10-2009 12:44 PM
cheap lift highflyer TJ Wrangler Technical Forum 18 06-25-2009 05:18 PM
Cheap Lift ryanhaley52 TJ Wrangler Technical Forum 13 06-14-2008 07:18 AM
3" econo lift(cheap suspension lift tips) rivers edge TJ Wrangler Technical Forum 16 09-13-2006 05:57 AM
Cheap Lift? Futbol4x4yj YJ Wrangler Technical Forum 6 04-25-2005 04:17 PM
