Chassis Lubrication - JeepForum.com
post #1 of 6 Old 12-04-2007, 08:07 PM Thread Starter
Jeebs
2015 JK Wrangler
Chassis Lubrication
Where exactly are all the chassis lubrication points, and how much is too much in the steering lube points? The boots already feel pretty firm to the touch.
Thanks in advance -
Jason
Jeebs is offline
post #2 of 6 Old 12-04-2007, 09:54 PM
goatboy
Well, I don't know if you've referred to your manual, or even if the manual has this information...but from my experience, I've never had a problem climbin' under the beast with a grease gun and puzzling it out! Not a difficult thing...you see a zerk, hit it a lick with the grease gun...if there's no zerk, don't...
goatboy is offline
post #3 of 6 Old 12-04-2007, 10:08 PM Thread Starter
Jeebs
2015 JK Wrangler
The Hayne's just says almost exactly what you did. I was looking for a rough count to try and ensure I didn't miss any.
Jeebs is offline
post #4 of 6 Old 04-07-2009, 12:20 PM
BChamberlin
BChamberlin's Avatar
What kind of grease do you use for this? I've never used a grease gun... are the attachemnts the same? I've actually got a TJ but found this under search. I could probably use some lube as well... never done it before.
2008 Wrangler X
BChamberlin is offline
post #5 of 6 Old 04-07-2009, 01:07 PM
AirForce
Head Hunter
AirForce's Avatar
On my 94 YJ, I have a zerk fitting on all 4 Tie Rod Ends (Drag Link and Steering Knuclkles), upper ball fittings, front and rear driveshaft UJoints, and all my greasable shackles. My ujoints in my front axles don't have zerk fittings. If your boots feel firm, I would not mess with it... you don't want to split out a boot.
I'm not sure if that's all of them, that's all I have run across so far! Have fun!
God Bless Our Troops!
AirForce is offline
post #6 of 6 Old 04-07-2009, 02:35 PM
blake989
^^^^^^one more on the front driveshaft slip-collar
EDIT: dang, didn't realize this was a few years old. I use a synthetic grease. And I have no clue about a TJ.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
Lubrication problems! BChamberlin TJ Wrangler Technical Forum 9 04-16-2009 07:33 PM
Lubrication for my TJ TheSherp TJ Wrangler Technical Forum 4 01-23-2009 03:15 PM
lubrication suggestions tjscoot00 TJ Wrangler Technical Forum 6 11-14-2008 06:19 PM
AX-15 Lubrication fogertyb TJ Wrangler Technical Forum 18 07-31-2008 10:15 PM
Suspension Lubrication MeatPuppet YJ Wrangler Technical Forum 4 02-24-2007 08:44 PM
