Chasing A Smell - JeepForum.com
post #1 of 4 Old 11-02-2003, 10:15 PM Thread Starter
YJHoller
YJHoller's Avatar
Chasing A Smell
Here is the situation. I swapped out my old 4.2 last winter and put in a 4.0 Since then there has been this lingering smell, which is a combination of oil/grease/exhuast. Has anyone had any similar experiences or know of some things to look at?
Just some more info about my YJ. Its an 88 with about 190,000 miles on it. The engine has about 160,000. Its a hardtop, with hard doors. 5-speed manual. Can't think of anything else that would be helpful. Thanks in advance.
Dan
1988 Wrangler Laredo
1991 4.0L HighOutput, 5-speed, Cherokee Seats, K&N Air Filter, 2" add-a-leaf, 31x10.5, rear locker, Ramsey winch
YJHoller is offline
post #2 of 4 Old 11-02-2003, 10:40 PM
PaxtonTransAm
PaxtonTransAm's Avatar
I would think about where you could be leaking oil, grease, and or fuel from and check there.....
98 Jeep Wrangler 4.0 Sahara, auto, alpine, JL audio speakers, 3chamber flowmaster,pace setter air intake, accell coil, a few other things
PaxtonTransAm is offline
post #3 of 4 Old 11-02-2003, 11:18 PM
*Jeremy*
I would check the cross member that holds up the tranny,my rear main was leaking and a bunch of oil collected on the top of it all by the cat converter and tranny and had that smell for awhile untill i took it down and cleaned it all off.
Its like the cat would warm that area up enough to give that smell but not hot enough to just burn it all off.
*Jeremy* is offline
post #4 of 4 Old 11-04-2003, 09:52 AM Thread Starter
YJHoller
YJHoller's Avatar
Good Call
I am not leaking fluid of any type, or atleast not much. But I will definately check the cross member. I actually have a skid-plate, which I guess would hold even more fluid. I appreciate the hint.
Dan
YJHoller is offline
chasing down the electrical gremlins NJscott YJ Wrangler Technical Forum 2 06-03-2009 07:14 PM
Help Chasing Electrical Gremlins wmshay6 YJ Wrangler Technical Forum 3 05-20-2009 10:18 AM
New Owner Chasing a Rattle Toolslinger TJ Wrangler Technical Forum 4 03-08-2009 11:50 AM
Chasing Vibration dtriplej6 YJ Wrangler Technical Forum 0 09-02-2008 10:31 PM
still chasing a clunk.... tman204 TJ Wrangler Technical Forum 3 01-05-2008 11:31 PM
