Chasing problems...... - JeepForum.com
post #1 of 10 Old 02-13-2013, 08:30 PM Thread Starter
jmfirefighter20
So my '90 with the 2.5 is ill......been having issues with starting/rough idle over the last few weeks (thankfully it's not my DD!). Ended up finding that the TBI injector was leaking by as the bottom of the intake manifold was full of fuel after sitting for a bit. Ordered up a new injector and replaced it.....well that didn't fix the problem!
I had been getting a little bit of oil on the air filter every now and then, but not a lot. I've checked all my PCV vent lines and such, and they are all clear. So on a hunch today I finally got around to pulling the plugs and running a compression test on her. Plugs looked good for all cylinders, however the compression was not so hot....
#1: DRY @ 140
#2: DRY @ 55, WET @85
#3: DRY @ 150
#4: DRY @ 140
Looks like cylinder #2 has a compression issue. I have yet to run a leakdown test on her, but do you think I need to? Isn't it if the compression increases for the wet test it's pretty clear it's a ring issue rather than a valve issue?
Either way, it looks like I'm in the market for a replacement engine unless someone thinks that I might be able to salvage the one I have now (unfortunately due to funds I am unable to upgrade to the 4.0, nor do I really have the desire to).
Anyone have any thoughts to help me decide to fix this one, or get a questionable junker from a yard or CraigsList? I appreciate the input!
'12 JKU
'90 Jeep Wrangler YJ
1975 IHC Fleetstar 2010A Fire truck
'01 Jeep GC Laredo (SOLD)
1962 IHC BC-160 Fire Hose Wagon (SOLD)
jmfirefighter20 is offline
post #2 of 10 Old 02-13-2013, 11:44 PM
jokerchief462
You have choices bu they are all dependent on $$$. Overhaul yours at a local shop I got lucky last year $1250 long block rebuild. JY engines are just that so you know what to expect. CL engines are dependent on who you are dealing with. Some have a long story stay away and some actually are straight up and tell you what you are getting. So shop around and see whats out thhere it may surprise you. If you have the time and $$$ overhaul your and get the engine back you take them. Serial numbers on the receipt and in your notes.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 10 Old 02-14-2013, 04:01 AM Thread Starter
jmfirefighter20
I'll have to get in touch with some machine shops in the area. I am THINK I am pretty comfortable around an engine and would have no problem putting the block back together as long as the machining was done for me and I was told what size/type of parts to buy, of if the shop would sell me the parts so I could put it together myself. Save on the labor cost having them put it all back together AND be able to give myself a pat on the back!
I got a mechanic friend the next town over so I'll have to go chat with him and see what suggestions he offers.
Thanks
'12 JKU
post #4 of 10 Old 02-14-2013, 06:41 AM
Que89YJ
Wait! You are assuming it's the engine. You could just have a valve issue. Pull the valve cover and look. Make sure you aren't losing the compression through the valve. How many miles? 150 is pretty good. I might consider trying to pull it though the bottom and replacing just 1 if it is still low miles, but definitely start with the upper end.
Que89YJ is offline
post #5 of 10 Old 02-14-2013, 06:47 AM
Renegad87
1987 YJ Wrangler
I'd say start by pulling the head and see what is going on. Depending on the mileage you may not need to spend all the money on an overhaul yet. I lost compression in cylinder 5 on my 4.2 one time and pulled the head to find that a small section of the head gasket had disappeared between the cylinder and the valve push rod "chamber". Not to say this is whats wrong with yours since I have no experience with the 2.5L but it's worth it to pull the head. You never know what you may find.
Renegad87 is offline
post #6 of 10 Old 02-14-2013, 07:06 AM
Que89YJ
LOL REN and I thought the same thing and posted at the same time! Sounds like good advice!
Que89YJ is offline
post #7 of 10 Old 02-14-2013, 09:34 AM Thread Starter
jmfirefighter20
That's actually a good idea I didn't think of. Is it possible that the wet compression test could have sealed up a leak of that nature enough to allow the compression to increase 30 psi? Like I said I always thought an increase in pressure during a wet test points to the rings/cylinder being the issue.
I have no idea about the number of miles on this engine. The chassis itself has 78000, but the engine is not original as it is out of an 89 XJ (had to chase down a pulley, and the dealer parts guy who is on the FD with me determined that this engine is not original). There is a marking on my fan shroud that says "60K" and a list of things (eng, tran) but somehow I think that is more of the mileage on the chassis when the motor was replaced and not the mileage of the motor.
I will look into this a little more before I drop any large amount of cash on this. I do have a source for a replacement engine with a trans that was from an 89 YJ which was pulled for a V8 conversion. Guy says it has 105K on it and that it ran fine (yeah, I know it's a risk either way), but for $200 for both it sounds like a decent but risky deal. I don't know if I should just pick it up JIC or wait but don't want to lose it to someone else. Every other pulled engine I have found has been outrageously priced with way more miles!
'12 JKU
post #8 of 10 Old 02-14-2013, 10:06 AM
Que89YJ
That engine sounds like a steal! I would grab it! Yes, you are right on the wet dry. I didnt catch that. l can only think of one more thing and that is bleed down for a bad/leaking head gasket.
Que89YJ is offline
post #9 of 10 Old 02-14-2013, 10:19 AM
ROTTEN
For $200 for an engine and trans I would still buy them as spares if $$ permits
I'm new
ROTTEN is offline
post #10 of 10 Old 02-14-2013, 10:20 AM Thread Starter
jmfirefighter20
I figured it was a steal too! The guy is going to hold the engine for me for a bit until I can make the two hour one way drive to get it.
'12 JKU
