charging system problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > charging system problems
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-22-2015, 05:32 PM   #1
jtrobbins234
1987 YJ Wrangler
hey so i built my jeep from the ground up right and now its all done how ever in not savy how to wire the charging system when i got the jeep it was stripped of all wiring and its all done done now however i font know how or where to hook up the voltage regulator or any of the charging system. im at a stopping point in till i need some help.
jtrobbins234 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 05:42 PM   #2
TheDonk
1987 YJ Wrangler
Not really sure what you're asking specifically, but check this thread out:
http://www.jeepforum.com/forum/f8/en...rounds-491290/
JeepHammer has some pretty useful diagrams in it.
For what it's worth, the voltage regulator in 87 was internal to the alternator. Unless you're working on something custom.
Hope that helps get you on the right track.
"Try not to become a man of success, but rather to become a man of value." - Albert Einstein
TheDonk is offline   Reply With Quote Quick reply to this message
battery , charging system , eletrical , help please , technical
