Charging System - JeepForum.com
post #1 of 7 Old 08-09-2010, 07:28 PM Thread Starter
VACJ5
Charging System
So I just installed my taurus fan, I got 100w hella headlights and a set of hella fogs. I have a stock alternator and an old cheap battery. Before I added the efan I had no issues, voltmeter read 13-14V at night with the headlights on and fogs on. Now if I am running the fan, and kick the headlights on I drop down around 10 or so, and when I turn on the fogs it drops to the red, about 8V or so (at idle). I rev it and as the alternator spins faster, naturally the meter jumps up. Sooo.... I am sure it is the fact that I have a cheap old battery doesnt help, but should I go ahead and get a higher output alternator?
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #2 of 7 Old 08-09-2010, 07:32 PM
jbolty
jbolty's Avatar
High amp alternaotr is a good upgrade but have the battery tested first.
Are you using the fan on low with a controller? Are you using good heavy wires for everything?
jbolty is offline
post #3 of 7 Old 08-09-2010, 07:41 PM Thread Starter
VACJ5
Yep, got some beefy wiring on it (after burning up some undersized wiring and switches). With how warm it has been it is running pretty much all the time. I have a yellow top in my truck, might swap the 2 battery's out. What is the output of the stock alternator?
VACJ5 is offline
post #4 of 7 Old 08-09-2010, 07:53 PM
idaholtby
Stock alt's are typically 75 or 90 amp. The part number on the alt will tell you what it is. If you were running fine before the e-fan, then check the maxi fuses in the PDC to make sure you didn't pop one of them. I don't see how the fan alone will cause the excess draw that you are describing, unless something is wrong with the fan motor.
idaholtby is offline
post #5 of 7 Old 08-09-2010, 08:08 PM
jbolty
jbolty's Avatar
I hope you are using proper relays and not directly switching the fan. A taurus fan draws something like 75 amps on startup and 35 or so running. It's important to have it only on when it needs to be, like with a controller. Also, if it's running at the same time as a bunch or lights you will run out of power pretty quickly.
If I run mine for very long with the engine off I can hear the belt squeeking and the alternator working pretty hard to charge the battery back after starting it.
jbolty is offline
post #6 of 7 Old 08-09-2010, 08:27 PM Thread Starter
VACJ5
Yep, I got it wired through a 60 amp relay, and that is only on the low side. I dont even have the high side wired. Aside from an adjustable fan controller, there are some that kick on/off at 180. Mine, like most 4.0's run at 210, so needless to say, the fan never kicks off, especially when we have been having 100 degree days. During the day when I dont need my headlights, I run at 13-14 volts with the fan on. So I dunno... maybe it is more about my headlights. hrmmm...
VACJ5 is offline
post #7 of 7 Old 08-09-2010, 08:27 PM Thread Starter
VACJ5
and my switch is wired into my ground, so there is little no no draw through it.
VACJ5 is offline
97 TJ charging system isn't BENG TJ Wrangler Technical Forum 12 03-09-2015 08:44 PM
Charging AC System kehoe TJ Wrangler Technical Forum 1 07-13-2009 09:25 AM
Charging system Robbypfd YJ Wrangler Technical Forum 5 04-07-2007 09:25 PM
charging system obsessedjeeper YJ Wrangler Technical Forum 4 04-06-2007 11:49 PM
Charging system udamann TJ Wrangler Technical Forum 6 07-16-2006 08:14 PM
