Changing the Water Pump - JeepForum.com
post #1 of 4 Old 09-18-2001, 02:57 PM Thread Starter
OhYeah
Hey friends,
I am going to be changing the water pump this weekend. Is the anything I need to look out for? How hard is this to do? Any advice is appreciated.
Thanks,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #2 of 4 Old 09-18-2001, 06:19 PM
osburn
osburn's Avatar
Ya need RTV and pipe sealer if I remember right. I'd open the box and read the instructions so ya don't find you're without something you need once you get started.
Matt Osburn
Score 1032
osburn is offline
post #3 of 4 Old 09-18-2001, 06:59 PM
my litte red yj
make sure you clean the block GOOD remove all the old gasket and make sure the metal pipe that is on the waterpump is good when i did my waterpump i replaced mine it was about $13.00 from the dealer it mite have a lot of rust, if it is rusty i (my opion) would replace it is worth the $13.00 insurance i was afraid it would leak it had a lot of rust on it it took me 1 hr once you remove the fan shroud it is easy
my litte red yj is offline
post #4 of 4 Old 09-18-2001, 07:08 PM
JeeperJay
I just did this last week. Its not too bad as long as you don't have a problem getting bolts off. You do need to remove the power steering pump and the pump mount to get to the water pump though. There's no need to disconnect the hoses though, just kinda move everything out of the way. I got it done in a few hours with no major problems. I also replaced that heater hose pipe that 'my litte red YJ' referred to. I'd also recommend flushing out the coolant system before you take anything apart so you don't have to deal with coolant while you're under the hood.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
My Newbie's Experience changing the Water Pump on my 1998 TJ, 4.0L I6, with P/S & A/C maisis00 TJ Wrangler Technical Forum 4 06-18-2013 01:31 PM
Coolant leak. After changing the water pump twice Gabe TJ Wrangler Technical Forum 26 11-13-2009 03:27 PM
changing the water pump on my 94 4L help! danmbyl YJ Wrangler Technical Forum 5 05-01-2009 02:05 PM
Changing my Water Pump Modfatha TJ Wrangler Technical Forum 4 06-13-2007 10:08 PM
Help changing water pump on a 95 YJ 2.5 Atlantic YJ Wrangler Technical Forum 1 06-09-2007 04:25 PM
