Changing unit bearings. Need to get new axle nut? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Changing unit bearings. Need to get new axle nut?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Clayton Off Road JK Short Arm Suspension Kits~Artec JK 1 TON SWAP~
Unread 04-02-2014, 05:18 PM   #1
RocketUSA
Can the 175 foot pound axle nut be reused after replacing the unit bearing? I'm seeing some conflicting info online. Dorman products places a "It Is Recommended To Replace Every Time They Are Removed" statement on their website. Of course they're in the business of selling product, but also in the business of not getting sued. I'm definitely leaning toward taking their advice.
What is the experience others have had?
RocketUSA is offline   Reply With Quote
Unread 04-02-2014, 05:30 PM   #2
jbolty
jbolty's Avatar
I have used the same nuts probably 50 times with no issue.
Never even thought of changing them. But, I always use brand new cotter pins, those will break at the bend quite often.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 04-02-2014, 08:18 PM   #3
92 Green YJ
Same here. I've never replaced the nut when replacing a busted shaft or unit bearing. I do have a few spares from the junk yard in my tool box. But yeah, always just re use what's on there. As far as I know they may well be 22 years old and from the factory
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Unread 04-02-2014, 08:35 PM   #4
laybackman
Bikini Bridge Inspector
laybackman's Avatar
Yes those nuts are not torque to yield like head bolts are.
Chicks dig me.....Fish fear me
Getting older, I have developed some special skills. I have the ability to cough, sneeze, fart and pee at the same time.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
laybackman is offline   Reply With Quote
Unread 04-02-2014, 09:11 PM   #5
Opihi59
from here it gets rough
Opihi59's Avatar
Wicked tight those things are. Start PB blasting every bolt/nut you're going to have to remove ahead of time and annoint them ceremonially a few times a day with liberal doses of PB. I've had no problems with re-using these either, and I like to antiseize them so it's easier the next time you pull them off again.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote
Unread 04-03-2014, 10:23 AM   #6
RocketUSA
Thanks for the feedback guys. Just to update, the nut was relatively simple, breaker bar with PB Blaster (applied over several days in small amounts) and it came off. Ok, so we had to stand on it, but it came off. The real trouble was un-fusing the hub from the spindle. Had to apply pressure with a puller, then tap on the center driver of the puller, then add more pressure, then tap. Over & over. It was a real bugger, but eventually came off.
Unread 04-03-2014, 10:32 AM   #7
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
I know its too late for you, but this may help someone else. The trick is to back out the bolts on the backside, leaving some threads in the hub an put a socket in there, wedged up against the knuckle, then turn the steering wheel into it to break it loose. My description may be a little fuzzy, it's been a couple of days since I did this, but I think you get the idea...
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote
Unread 04-03-2014, 10:59 AM   #8
RocketUSA
"Put a socket in there..."
Where exactly?
Unread 04-03-2014, 11:01 AM   #9
Varnish
Varnish's Avatar
In between the yokes of the axleshaft so it can't bend/turn where the ujoint is.
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
'99 XJ 4dr SE
Varnish is offline   Reply With Quote
Unread 04-03-2014, 11:30 AM   #10
laybackman
laybackman's Avatar
Where exactly?
https://www.youtube.com/watch?v=8Ly3pC8tzDc
Unread 04-03-2014, 12:58 PM   #11
Anticanman
Follow me
Anticanman's Avatar
The trick is to use a gear puller on a work bench
And the real trick is to wheel with shafts ready to install
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote
Unread 04-03-2014, 02:18 PM   #12
dtperk
HA! That's awesome AM!
(RIP) '82 CJ-7 | AMC 4.2 (.30 Over), T-4 / D300 | D30 Front - LockRight, AMC20 Rear - ARB, Moser Axles / 4.10s | York Air Setup - 2.5 Gal Reserve, QD's Frt/Rr | 2.5" SUA, 1.5" Shackle & .75" Body | 4WDH Glass Tub, Fenders & Hood | Stainless all the way around | 33" BFG MTs
dtperk is offline   Reply With Quote
Unread 04-03-2014, 02:37 PM   #13
Opihi59
Opihi59's Avatar
Somewhere on the forum, or on Stu Olson's site, there is a writeup on this process, including the "socket technique" of getting the unit bearing separated from the hub. At work, I am somewhat limited by firewalls, but I will try to find the link and post it in.
Try this: http://www.jeepforum.com/forum/f12/a...a-30-a-360209/
It may not cover the unit bearing, and I cannot see the photos at work, but from the narrative it seems this socket technique is described, and likely there are illustrative photos.
You'd never believe some of the techniques I've resorted to in undoing those axle nuts, not just on Jeeps. I now have a mongo powerful impact wrench, and an "I'm overcompensating" air compressor so it's a simple process of brute force.
Unread 04-03-2014, 05:30 PM   #14
Mobile_Homie
Desert Rat
I had mine out in ten min in the driveway and didn't have to pull the axle or replace seals. Either way...
Mark
Click here
Unread 04-03-2014, 05:43 PM   #15
Opihi59
Opihi59's Avatar
Semtex sure is some handy stuff to have around........
