questions about body lifts - JeepForum.com
post #1 of 6 Old 05-20-2010, 08:26 PM Thread Starter
Mudmouse990
ok so i dont want much and i dont want to go through that much trouble i know suspension is the way to go but im just lookin for a cheap lift for now i was thinking two inches of body lift and then a one inch shackle lift i hear mixed opinions but what do u think will the body lift require any difficult mods all the kits say that everything is included but im not sure , any suggestions will be helpful thanks
Mudmouse990 is offline
post #2 of 6 Old 05-20-2010, 08:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/b...-w-pix-705291/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 05-20-2010, 08:36 PM
chico166
chico166's Avatar
My YJ had a 3" BL on it when I bought it. The PO welded the steps bars just under the body on the frame, so I can't take the BL off until I cut the step bars off. When I do, I will remove the BL and replace with a 1" or nothing at all. My suggestion is either do a 1" or nothing at all. nything more is a PITA and doesn't look good in addition to being virtually useless. Nothing had to be altered with the one on mine the best I can tell.
2013 JK Unlimited Gecko Green, 4" Skyjacker lift. Pro-Comp 35" Xterrain tires
chico166 is offline
post #4 of 6 Old 05-20-2010, 08:42 PM
wv2jeep
I'd save your money for a suspension lift,I know thats not what you want to hear but a body lift is like 80-125 dollers and shackles like 50-100 bucks.If you go to put a body lift and the old bolts break,which is very common on the yj it can turn in to a nightmare.For like 450.00 you can get a rough country 4in suspension that comes with everything you need and with new shocks and springs it will tighten everything up and drive nice.I think jeeps look bad with just a body lift with stock suspension.just my 2cents
wv2jeep is offline
post #5 of 6 Old 05-20-2010, 08:49 PM Thread Starter
Mudmouse990
yeah suspension is the way i want to go but i didnt know if bl and shackle would be a cheap alternative but i get what your saying i think ill just go for the suspension thanks
post #6 of 6 Old 05-20-2010, 09:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Body lift and shackle lift is a great ADDITION to a suspension lift, not an alternative.
Anticanman is offline
body lift , jeep yj , shackle lift
Newbie questions (body lift, suspension lifts and lockers) GoldenP51 TJ Wrangler Technical Forum 9 08-12-2009 12:43 PM
What is the best.... (suspension lifts and body lifts) RjAndJeep TJ Wrangler Technical Forum 24 06-03-2009 09:33 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-28-2009 12:21 AM
Questions on lifts and body lifts WrangBlake TJ Wrangler Technical Forum 3 10-06-2006 02:46 PM
questions about1'' body lifts blacktj27 TJ Wrangler Technical Forum 12 04-13-2005 07:32 PM
