Quantcast changing trans/transfer fluid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > changing trans/transfer fluid
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 02-23-2005, 11:44 PM   #1
vwbeatle1214
i'm changing thansmission fluid, transfer case fluid, and diferential gear oil
what types are you guys using , and how much should i buy since i wont be able to get back out once i drain it. i usually run synthetics so i will probably be sticking with the same here unless theres a reason not to.
thanks
Randy
94 YJ 2.5 4 cyl 5-spd
homemade snorkel w/ hyundai elantra airbox
urban camouflage paint
trail customised exhaust
3.5" dick cepek lift
3/8 " m.o.r.e boomerang shackles
31x10.50 m/t's
vwbeatle1214 is offline   Reply With Quote
Old 02-24-2005, 08:38 AM   #2
xoolinzyoox
You most likely just need ATF 3 or dex 3 .. go to murrays or autozone and ask them
i dont know how much ur trans takes... i would day 5-7 cause a tf999 takes 5 quarts .. dont really know that - ask the autoparts guys
xoolinzyoox is offline   Reply With Quote
Old 02-24-2005, 09:17 AM   #3
JayJEEPguy
Check out the FAQ sticky Post at the top of the page.
I run Mobil1 ATF in the transfer-case. I bought 3 quarts last time, but did not use them all. I save one for when I have to top it off (leaky seal).
Trans: Not sure
Diffs: Pretty sure it is normal diff fluid.
Jason T.
'05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip
http://www.cardomain.com/id/MourningWoody
JayJEEPguy is offline   Reply With Quote
Old 02-24-2005, 09:32 AM   #4
vwbeatle1214
well the sticky says 80 weight gear oil in the trans, has anyone used a synthetic gear oil in there and did you notice a difference?
31x10.50 m/t's
Glock Forum
