Changing the Shift Knobs - JeepForum.com
post #1 of 3 Old 09-20-2012, 08:51 PM Thread Starter
wrangler_bear
Very simple question guys. Got some chrome knobs for the 4wd and gear shift knobs. How do I take these off? Do I screw them off or is there some sort of screw in the top under the gear display cap and I have to pry it open? I'm very heavy handed and don't wont to unscrew something when it's not meant to be unscrewed. As I said...very simple question.
wrangler_bear is offline
post #2 of 3 Old 09-20-2012, 09:04 PM
sxi4evr
there should be a jam nut under the knob...turn it in the tightening direction then just unscrew the knob in the normal counter-clockwise direction
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline
post #3 of 3 Old 09-20-2012, 10:32 PM
Opihi59
from here it gets rough
Opihi59's Avatar
You would just never imagine what is in the FAQ or what comes up with a search on this forum, it's amazing.
http://www.jeepforum.com/forum/f12/b...-knob-1118702/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
installed newly used shift knobs-and bap YJ Wrangler Technical Forum 4 09-05-2012 09:49 PM
New Drake BLACK shift knobs and CB mount GXP20T JK Wrangler Technical Forum 1 11-04-2011 05:01 PM
Aftermarket shift knobs rredrunner TJ Wrangler Technical Forum 8 10-07-2008 04:30 PM
Changing shift knobs? fuzzbal981 TJ Wrangler Technical Forum 12 02-26-2006 02:22 PM
Stick Shift Knobs Jerry All-Bran TJ Wrangler Technical Forum 9 01-03-2005 12:01 PM
