Changing Shift Boot help removing old knob - JeepForum.com
post #1 of 4 Old 10-12-2011, 02:11 PM Thread Starter
91YJRedrock
I am replacing the old worn shift boot on my YJ the owner before me (who had no idea what he was doing to anything on this machine) glued the shift knob to the stick. i dont want to replace the entire stick. Would Grinding it off compromise the integrity of the shaft. or are there any solvents or anything that remove epoxy or glue. i have tried heating up where the epoxy is and removing the knob but no hope.
91YJRedrock is offline
post #2 of 4 Old 10-12-2011, 02:17 PM
jgillespie
IMO grinding would compromise the integrity of its structure. Any time you add a joint somewhere, it is a potential place of weakness. I would grab a larger set of channel locks, and a cheater bar. Set the channel locks to a size that lets the handles come close to touching together, or preferably touching. Slide the cheater bar on the end and pull like hell.
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #3 of 4 Old 10-12-2011, 04:08 PM
jmmorgan82
2009 JK Wrangler
Maybe try cutting through the knob somehow with a sawzall or use some sort of grinder to cut through it. Try to get it just deep enough so it doesn't hit the threads then pry it off with something.
jmmorgan82 is offline
post #4 of 4 Old 10-12-2011, 07:01 PM Thread Starter
91YJRedrock
The only solution to this was to grind at the base of the knob until it popped off. i have no threads, but at least i wont smell my exhaust leak as bad now. ill just rethread it when i get the chance.
boot , knob , shift , transmission
Changing Automatic Shift Knob deerassassin22 TJ Wrangler Technical Forum 23 03-30-2014 10:02 AM
Any luck changing the gear shift knob? ChadGoldenberg JK Wrangler Technical Forum 9 01-24-2012 07:14 PM
removing the shift knob help? massjeep TJ Wrangler Technical Forum 6 10-01-2009 07:40 PM
Removing shift knob ss454 YJ Wrangler Technical Forum 1 01-05-2009 05:10 PM
New Shift Boot and Knob Pipedrummer TJ Wrangler Technical Forum 16 02-15-2007 05:33 PM
