Changing serpentine belt on a 1994 Wrangler - JeepForum.com
post #1 of 6 Old 04-08-2006, 06:26 PM Thread Starter
Rocky529
Rocky529's Avatar
1994 Wrangler
6 Cylinder
No air conditioner
I tryed searching, but I believe it is time to change my dad's serpentine belt on his Wrangler. I do all my own maintenance on my 2004 Wrangler, but I am not familiar with the belt's setup on a 1994 Wrangler. Mine has an auto-tensioner... and I know his doesn't. I recall there being a bolt by the alternator that I loosen... take the belt off, install the new one and then torque down the same bolt? Is that it? If so, what's the torque spec for that bolt?
Thanks in advance.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #2 of 6 Old 04-08-2006, 06:35 PM
PhilipJ
PhilipJ's Avatar
The tensioner is underneath the power steering reservoir, you can't miss it. It's super long and a pain in the *** to turn.
20-25 ft lbs on the mounting bolts and 20 ft lbs on the tensioner.
And a new belt should be tightened between 180-200 lbs, tested between the idler and power steering pulleys.
PhilipJ is offline
post #3 of 6 Old 04-08-2006, 06:36 PM
jeffy
jeffy's Avatar
The tensioner should be built into the P/S pump mount. There should be 3 15mm bolts. Two in the back and one in the front, I think. Once the P/S is loose, you can loosen the lock but for the tensioner. The tensioned is a long screw that is perpendicular to the engine on the driver side. Loosening it will bring the P/S in and loosen the belt.
*** www.4BangerJP.com ***
jeffy is offline
post #4 of 6 Old 07-27-2006, 10:02 PM
951 freak
serp belt problems
i just did my water pump and i was going to replace the serp belt problem is i have the right belt but it is too big and everywhere i lookfor diag i see idler pullys i dont have any on my motor and i did not take any off so what can i do?
951 freak is offline
post #5 of 6 Old 07-28-2006, 02:47 AM
wwiihistory
wwiihistory's Avatar
When your done running it for the first time...you will probably need to retighten it due to its stretching a bit. Happened to mine when I changed it.....squeeled after a few days and had to adjust more.
Happiness is a belt-fed weapon
95 Sahara, 4.0L, 5 spd, Olive/Tan, HT,HD's, 31's,3.07s
Military Jeep club member 1941,1942,1943,1944, and 1945
wwiihistory is offline
post #6 of 6 Old 07-28-2006, 03:45 AM
jipjip
jipjip's Avatar
not on an I6, the tensioner pulley is next to the power steering pump. you loosen the center bolt of the pulley, then theirs a long bolt at the top of the pulley you loosen to make the pulley release tension on the belt.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
Serpentine belt help 1998 wrangler ble10 TJ Wrangler Technical Forum 5 11-15-2009 02:26 PM
Replacement of 98 Wrangler Sport (W/ A/C) Serpentine Belt yawnocmot TJ Wrangler Technical Forum 14 09-10-2008 12:27 PM
Changing the Serpentine Belt on an 01 SE TJ 01amberfirewv TJ Wrangler Technical Forum 6 06-26-2008 04:28 PM
Changing serpentine belt on a 2004 Wrangler Rocky529 TJ Wrangler Technical Forum 38 03-19-2006 01:17 PM
2000 Wrangler Serpentine belt voigtrobert TJ Wrangler Technical Forum 4 10-24-2005 06:59 PM
