Changing from round LED tails to factory tails - JeepForum.com
post #1 of 6 Old 08-20-2011, 12:15 PM Thread Starter
PotentialYJNewb
1987 YJ Wrangler
Hey guys. My PO has the round LED tails installed on my Jeep. I ordered the factory ones because I wanted to put those on, and when they arrived I realized I was probably missing a few more things in order to change back to the factory tails.
When I took apart the round LED's to see what I needed to do I found this:
Obviously, to fit them, they had to be installed like that, so it seems like a part of the tub was just cut, and I would need something there with screw holes to replace them with the factory tails in order for them to stay put.
These holes:
I assume that's how it has to be done. So has anyone ever went back to the oem tails from the round led's? What piece do I need/where can I get it or what do I need to do to complete this installation?
PotentialYJNewb is offline
post #2 of 6 Old 08-20-2011, 12:39 PM
92 Green YJ
92 Green YJ's Avatar
Think you are probably the first to o back to stickers from flush mounts. Basically I would make a patch panel and weld it in. Mark and drill the holes, then tack some nuts the right size to the back side. Bout all I can reallynthink to do to switch it back
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #3 of 6 Old 08-20-2011, 12:41 PM
phil1330
1964 CJ5
^^^^X2
or just keep the LEDs
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #4 of 6 Old 08-20-2011, 12:47 PM
Xpress
I personally have never liked the LED rounds. They don't say Wrangler to me.
All about that unibody life.
Xpress is offline
post #5 of 6 Old 08-20-2011, 01:07 PM
eess
These holes:
How about corner armor. Black, stainless, painted, whatever you like. Then bolt the new lamps to that
92 YJ, 350/350 Chevy, AX-15, Skyjacker 4", 4.10s, CJ style flat dash with Autometer Phantoms
eess is offline
post #6 of 6 Old 08-20-2011, 01:16 PM
92 Green YJ
for once I actually agree with you. thats why I went with these on mine
My
L.E.D. tails a different way NJscott YJ Wrangler Technical Forum 5 10-05-2009 07:23 AM
LED Tails icehead14 YJ Wrangler Technical Forum 9 07-31-2009 11:08 PM
Round Tails. Tompatt YJ Wrangler Technical Forum 34 08-07-2008 05:10 PM
problem after l.e.d tails 4bangersRme YJ Wrangler Technical Forum 6 07-21-2006 08:23 AM
Did you install rear sidemarkers with your round LED tails? SteelBlueTJ TJ Wrangler Technical Forum 6 03-02-2006 11:22 AM
