Changing pulley wheels on Alternator? - JeepForum.com
post #1 of 10 Old 03-31-2010, 10:59 PM Thread Starter
Morgans_YJ_93
So my alternator just went out in my 4.0 93 YJ. Its only pushing around 10 amps to the battery. I went out and got another one from a junk yard (this may not be what people recommend, but its what my budget allows for right now) that seems to be the exact same alternator, same manufacture, same bolt line up. But there is one difference, the pulley wheel on the new one is a bit bigger then the original one.
I tried removing the bolt that holds the wheel on but it is fairly stuck, even after applying some bolt buster. Also it is quite difficult because the wheel always wants to turn on you. Does anyone have any recommendations on how to remove this wheel?
Also is it necessary to remove the wheel. I figured that a smaller wheel would be better since it would turn more revolutions, but thats just what made sense in my head.
Thanks JF
Morgans_YJ_93 is offline
post #2 of 10 Old 03-31-2010, 11:29 PM
PlatinumNiner
You have to use a puller to remove the pulley it's pressed on. How much bigger? If it's a hair you will be fine. If its a lot you may have charging problems at idle. Have you tried it yet? Are you sure the inside of the pulley isnt the same side and the lip on the outside isnt just a little taller? Worst case you bring them both to autozone. They will rent you a tool on the spot to remove both pulleys and swap them over. Do right there and return the puller. Its a free rental.
PlatinumNiner is offline
post #3 of 10 Old 03-31-2010, 11:38 PM Thread Starter
Morgans_YJ_93
The circumference of the original one is 6 inches, and the circumference of the second one is 7 inches.
That is about a fourth of an inch difference in the diameter of the wheel.
Will that second wheel be ok to install? Or do i need to replace the wheel.
post #4 of 10 Old 03-31-2010, 11:43 PM
PlatinumNiner
No way the pulley is that big on an alternator? They are tiny little pulleys. Doesnt make sense to me. As an example the pulley is normally small enough to fit the cap to a paint can over.
post #5 of 10 Old 04-01-2010, 12:35 AM
MJMPC
How about a pic of the alt and pulley? Like said some are pressed on but most have a nut to remove.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #6 of 10 Old 04-01-2010, 12:46 AM Thread Starter
Morgans_YJ_93
This one had a nut to remove. No pics cuz i lost my phone in Australia
But i just put the newer one on deciding it would be better to have something on there rather then nothing for my commute tomorrow.
When I started it up, the battery immediately went from being pretty much no charge to having a little over normal. So i dont think this bigger wheel does any better or worse then the other. Im just gunna leave it and get rid of my old one.
Thanks for your help
post #7 of 10 Old 04-01-2010, 01:04 AM
T-birdJunkie
2002 KJ Liberty
Circumference or Diameter is 7"?
If it's circumference, an inch shouldn't be so bad...if we're talking diameter...that's a HUUUUUUUGE difference.
T-birdJunkie is offline
post #8 of 10 Old 04-01-2010, 01:11 AM
MJMPC
The kind with the nut are best done with a impact wrench you can hold the pulley to stop it turnning.. If the pulley is bigger than stock all it will do is slow the alt down a bit wont hurt anything.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #9 of 10 Old 04-01-2010, 04:06 AM
Alfons
The slight difference in pulley size won't make any difference. I've used both pulley sizes with the YJ alternators and have had no problems and no measurable difference in output.
Alfons is offline
post #10 of 10 Old 04-01-2010, 07:27 AM
PlatinumNiner
The nut holds the pulley in place however its still pressed on. You cant just remove the nut and have the pulley pop right off. 1" isnt crazy but i have never seen any alternator pulley that was 6 or 7 inches around. I looked up the replacement part for the 93 YJ 4.0 and the pulley is small maybr 4" around. Who knows either way glad it works. Just make sure it charges at idle.
help getting the alternator pulley off quiksilverj TJ Wrangler Technical Forum 3 02-13-2009 09:21 PM
alternator pulley bent Anonymous6915 YJ Wrangler Technical Forum 3 02-10-2009 02:38 PM
Idler/Alternator Pulley Bearings Stafford TJ Wrangler Technical Forum 3 04-11-2008 02:19 PM
Removing Pulley from Alternator atomicmoose YJ Wrangler Technical Forum 12 12-20-2006 10:29 AM
changing belt (alternator) question? BOTLFED98 YJ Wrangler Technical Forum 6 11-17-2003 04:10 PM
