Changing Oil Pan Gasket - JeepForum.com
post #1 of 2 Old 09-08-2003, 09:18 AM Thread Starter
Leroux
Leroux's Avatar
Within the next couple of weeks im going to be changing my oil pan gasket. Its developed a very slight leak on the front, under the (?crank pulley?). I tightened down all the bolts on the pan and it seems to have stopped it for now, but I still want to fix it right. Is there anything else I should look at or have changed while I have the pan off? I also have a very quite knock when the engine is cold, any ideas? It has 158K miles on it.
Thanks in advance,
Leroux
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline
post #2 of 2 Old 09-08-2003, 09:39 AM
E_ROCK
Thanks in advance,
Leroux
If your rear main seal is leaking too, it is a good time to replace it when the pan is off. But, I am not sure I would replace if it wasn't leaking.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
Changing my head gasket MSFIT TJ Wrangler Technical Forum 2 04-21-2008 12:48 PM
Need new gasket for oil plug when changing oil? Dirty Backroads TJ Wrangler Technical Forum 5 03-29-2007 05:12 PM
Changing diff cover gasket and front gasket on diff Laxstar46 TJ Wrangler Technical Forum 2 10-11-2006 07:33 PM
Changing head gasket Sfrid073 TJ Wrangler Technical Forum 0 09-06-2006 05:30 PM
new gasket when changing gear oil mytjnamedrex TJ Wrangler Technical Forum 5 09-30-2001 04:45 PM
