Changing fluids - JeepForum.com
post #1 of 5 Old 11-04-2011, 09:50 AM Thread Starter
coleslaw
1987 YJ Wrangler
Changing fluids
Hey Guys,
Can I take off the skid plate under the tranny to change the oil without having to support the tranny? I can't get to the drain plug with it on.
Coleslaw
A country that tries to spend itself to prosperity is like a man standing in a bucket and trying to lift himself by the handles.
Winston Churchill
87 YJ I6, nuttered and rushed, 2.5" lift, 31x10.5, custom made f&r bumpers, Mojave heater, TJ flares, Superwinch S9000, hm swingout tire carrier, tool drawer, custom electical control, and more in the works...........
coleslaw is offline
post #2 of 5 Old 11-04-2011, 10:08 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
You will need to support the trans/t-case if you remove the belly pan. Is the plug really inaccessible, I don't know about standards, but I know I can get the pan off my auto without dropping the skid...
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 5 Old 11-04-2011, 10:18 AM
bogleparsons
Just put a floor jack under the transfer case and you'll be fine.
I have the AX-5 and the drain plug is in a very convenient place.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #4 of 5 Old 11-04-2011, 10:18 AM Thread Starter
coleslaw
1987 YJ Wrangler
Yea, I even took it to my local oil change place and they couldn't do it either. I would call that an engineering snafu!
Coleslaw
Winston Churchill
coleslaw is offline
post #5 of 5 Old 11-05-2011, 06:09 AM Thread Starter
coleslaw
1987 YJ Wrangler
Got it done. You can get to the drain plug with the pan on but the oil will just run into the pan, no hole to go through. You can't get to the fill hole with the pan on however and it isn't easy with it off. Here is bit of info for anyone doing this. The fill and drain plugs on the B10/5 tranny take a 5/16 male pipe plug socket to get them out. Bloody engineers!
Thanks all
Coleslaw
Winston Churchill
coleslaw is offline
Changing all of my fluids JJeeper09 TJ Wrangler Technical Forum 28 03-29-2011 02:06 PM
Changing fluids Quahitis TJ Wrangler Technical Forum 3 08-13-2008 09:52 AM
Changing fluids jmhat98 YJ Wrangler Technical Forum 3 08-26-2007 06:29 PM
Changing Fluids PolloLoco TJ Wrangler Technical Forum 1 06-20-2006 05:49 PM
Changing Fluids? jeepdan TJ Wrangler Technical Forum 3 01-03-2003 06:34 AM
