Changing fluid on a AX5 - JeepForum.com
post #1 of 22 Old 03-03-2009, 09:03 AM Thread Starter
MikeyJ
I want to change the transmission fluid on my AX5, I have a scrape going into 2nd gear sometimes and would like to try to quiet this down/prevent further damage to the syncro. What's the best fluid for my tranny? Where is the drain plug and fill hole?
Thanks in advanced
MikeyJ is offline
post #2 of 22 Old 03-03-2009, 10:37 AM
moonshinefuel
just go to jiffy lube.
moonshinefuel is offline
post #3 of 22 Old 03-03-2009, 10:39 AM
moonshinefuel
i know im going to get slammed for the jiffy lube comment. ahh well, i thought it was funny
post #4 of 22 Old 03-03-2009, 10:44 AM
jbach
the general consensus here is either Redline MTL or Penzoil Syncromesh. I have Penzoil in mine with good results. Drain plug should be on the botton and fill on top lol. Sorry can't remember exactly where they are but I know you need torx for at least one of them. Open the fill plug before draining.
jbach is offline
post #5 of 22 Old 03-03-2009, 10:46 AM
OneCleanYj
I ran Syncromesh in my last tranny and it made a big difference when shifting, 4th to 3rd was grinding a lot and it was more or less gone after adding Syncromesh. My current tranny is on it's way out already (POS AX-5!), so I opted for some cheap 70-90w instead of treating it to some good stuff.
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #6 of 22 Old 03-03-2009, 10:46 AM
Beater37887
The fill plug is on the passenger side if I'm not mistaken....DO NOT remove the plug that requires the Torx bit as it should be labeled DO NOT REMOVE and will screw your tranny (or so I've heard) if you do remove it. I've slept since the last time I checked my fluid but I believe it's a regular plug.
Beater37887 is offline
post #7 of 22 Old 03-03-2009, 11:42 AM
jordanw_125
How much does synchromesh cost?
jordanw_125 is offline
post #8 of 22 Old 03-03-2009, 01:36 PM
ritjobbie
Redline MTL is ~$10/quart around here. Synchromesh is about the same. Purple is $15/quart. IIRC, you need just less than 4 quarts to fill an AX5.
I use MTL and love it, especially for cold weather shifting. It made all the difference in the world for my AX5.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #9 of 22 Old 03-03-2009, 01:39 PM
ritjobbie
DO NOT REMOVE THE TORX! The drain is on the bottom and the fill is on the passenger side right next to the torx bolt. I think it was about 1 1/8" socket for the fill and drain plugs, but don't go out and buy a socket based on my memory. On my AX5 the fill plug had a small raised circle in the center of the flat face of the plug.
Always remove the fill plug first. Draining the fluid to find out that you can't put more in leaves you in a crappy place.
post #10 of 22 Old 03-03-2009, 01:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
FWIW, I tried Penzoil Syncromesh in my AX-15 and it was better initially it was just as bad as gear oil within a short period of time. I also tried ATF as recommended by a tranny shop (buddy of mine) and it was no better.
Finally I used 10W-30 motor oil and it has worked excellent for me for a few thousand miles now!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #11 of 22 Old 03-03-2009, 03:24 PM
sitdwnandhngon
1987 YJ Wrangler
x2 buddy^^
I use 10w40 on the graph it was a little closer to 75w90
15w50 looks like the closest. But 10w40 is stocked on every gas station shelf in the country. No problems with mine and it's had a rough year.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #12 of 22 Old 03-03-2009, 04:25 PM
snaustin09
I have the same problem as the OP, definitely need some new tranny fluid, I think I'll give Redline a try.
"If the ladies don't find you handsome, they should at least find you handy" -Red Green
snaustin09 is offline
post #13 of 22 Old 03-03-2009, 04:49 PM Thread Starter
MikeyJ
So now it comes down to redline vs syncromesh... I just want to quiet the damn scrape.
MikeyJ is offline
post #14 of 22 Old 03-03-2009, 04:52 PM
Ridin' Around
You can also use Amsoil's MTF. I sell it for $8.30 per quart plus shipping, PC price.
Keep this in mind. You need a GL-4 fluid as the GL-5 typically uses a sulphur based additive to make it pass the EP certification. As the sulphur gets hot, it becomes acidic. The acid is what causes the damage to the Yellow metals of the syncros. So don't just put any old fluid in to the AX trannies.
Ridin' Around is offline
post #15 of 22 Old 03-03-2009, 06:23 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
No, RL or SM or 10W-30 motor oil. I've got 1000 miles on an AX-15 with 10W-30 and all is perfect. Figure it this way, motor oil is easy to try, cheap, readily available with no shipping charges, and if you don't like it, drain it and put it in your motor.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
Changing clutch fluid and what fluid to use. RedDawn TJ Wrangler Technical Forum 4 05-08-2009 01:34 PM
YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid GMC7000 YJ Wrangler Technical Forum 12 11-04-2008 07:11 PM
Changing AX-5 fluid newcaddy4j TJ Wrangler Technical Forum 1 11-02-2007 01:55 PM
Changing fluid in BA 10/5 thisfatguy YJ Wrangler Technical Forum 4 07-30-2006 12:12 PM
Changing diff fluid Skully TJ Wrangler Technical Forum 10 03-23-2004 07:50 PM
