Changing cowl seal -
post #1 of 1 Old 11-30-2011, 07:30 AM Thread Starter
Changing cowl seal
Hi jeepers,, I will be changing my cowl seal soon and read a bunch of advise for how to do it,, the most common problem is the seal being so thick , it is hard to get windshield closed and requires some frame adjustments.. I also wanted to add that getting the seal warm first will help the rubber seal squish a little easier,, several ways to do this, but the best is to leave in sun for an hour before installing, other ways,, a blow dryer,, starting your engine and setting on your air filter ( be sure it doesnt fall into fan!!).
I will let you all know if this helps,,
Just another bit of advice for everyone,, Ever had a rubber hose that was just a little too small to expand over fitting?? Take a hammer and pound on end of hose gently untll it gets warm and it should slide right on..
Sprinter31 is offline
In order to be able to post messages on the forums, you must first register.
Bad fit cowl seal? ZacoWacko YJ Wrangler Technical Forum 11 10-28-2010 07:10 AM
Which cowl seal to get? 1bad92yj YJ Wrangler Technical Forum 8 11-02-2009 06:31 PM
Cowl seal czjeeper YJ Wrangler Technical Forum 0 01-29-2008 05:28 PM
Cowl seal jeep couple YJ Wrangler Technical Forum 6 10-18-2006 11:38 AM
cowl seal flyfisherman YJ Wrangler Technical Forum 12 08-02-2005 02:57 PM
